Go to Post Robotics. Seems to be the answer to a lot of things I don't do. - Keith Chester [more]
Unread 07-02-2009, 13:37
Drake Hunter's Avatar
Drake Hunter Drake Hunter is offline
Fighting Rednecks
FRC #2883 (F.R.E.D)
Drake Hunter is an unknown quantity at this point
Driver Station Help
Ok, so the problem we are having right now is that our Driver Station doesn't boot up, it stays as a blue blank screen so we can't even re-flash it, or do anything to it. Please give us information on what to do, please help we need this to work to continue on our robot. Thank you very much.
Unread 07-02-2009, 14:56
Urban Hawk Urban Hawk is offline
Head of R&D and Head of Scouting
FRC #1886
Team Role: Scout
Urban Hawk is infamous around these partsUrban Hawk is infamous around these partsUrban Hawk is infamous around these parts
Re: NEED HELP!!!
since i am not certain of the exact problem go to here and then look though the control system manual. the sections of it that would be of the most help to you would be 2.2.4 through the rest of that document which explains how to set the drivers station up and test it, 3.1.5 which explains about the software for it and 3.1.6 which explains the inputs and much more importantly the outputs of the drivers station. Since i don't know exactly what is going on with your drivers station I can't be more specific unfortunately.
http://www.usfirst.org/community/frc....aspx?id=10934
FEAR THE HAWK!!!
Unread 07-02-2009, 15:36
Fighting Rednecks
FRC #2883 (F.R.E.D)
Re: NEED HELP!!!
I was able to figure it out...thanks
Unread 07-02-2009, 15:52
FRC #1886
Team Role: Scout
Re: NEED HELP!!!
your welcome
FEAR THE HAWK!!!
Unread 07-02-2009, 16:08
David G David G is offline
FRC #2518
David G is an unknown quantity at this point
Exclamation Re: NEED HELP!!!
2518 ftw!
ok this is carlos equihua
our team 2518 have a type of vertical convier belt on out robot to pick up the balls, but we have problems when they try going up
we tried hooks(didn't work) but we tried velcro and that worked but we don't know if that interfears with some of the rules can someone plz help us?
if you know anthing call or reply!
#! ---> (651)-306-7106 at 3:00pm.- 4:30pm. central time! (O_O)
( )_( )
(^_^)
(")_(")
Unread 08-02-2009, 14:53
FRC #1886
Team Role: Scout
Re: Driver Station Help
as far as i can tell it doesn't break any rules.
FEAR THE HAWK!!!
Unread 08-02-2009, 14:59
The only way it would would be if it damaged game objects routinely.
Driver Station S.O.S. M. Gildner Electrical 15 28-11-2009 19:35
Help, our driver station is permanately stuck in enabled. eNyoron Electrical 4 27-01-2009 15:43
driver station and cRIO firmware update help asianfez123 FRC Control System 1 16-01-2009 02:34
Help with updating firmware on Driver Station urg8rb8 FRC Control System 3 28-12-2008 02:53
Driver Station Help.. 1708xMr.Roboto FRC Control System 8 22-12-2008 15:24
