Go to Post Who knew a single variable could be so deadly? - 3DWolf [more]
Unread 07-02-2009, 14:36
Christine_Ilich's Avatar
Christine_Ilich Christine_Ilich is offline
Team Musician and Human Cannon
FRC #2910 (Jack in the Bot)
Team Role: Human Player
Christine_Ilich is an unknown quantity at this point
Red face passing image data through vi's
how do we pass the image data through vi's?
we are a rookie team and it would be much appreciated if we could have a little bit of help.
Thanks
~Jack in the Bot
~A BENDY STRAW~
www.freewebs.com/jitb
www.etherpad.com/jitb2910
Unread 07-02-2009, 15:35
Re: passing image data through vi's
The subVI for Find Two Colors passes the image through as an example. There is also a subVI inside that creates lots of images and passes them out.
The control that dose this is an Image refnum, and it is also in the palettes next to the image display.
Greg McKaskle
Unread 07-02-2009, 15:37
thank you so much.
that was a big help.
~Jack in the Bot
~A BENDY STRAW~
LabView Functions Palette missing WPI VI's ksquared NI LabVIEW 1 31-01-2009 15:03
Using the analog sensor .vi's Hazmatt NI LabVIEW 5 13-01-2009 22:57
How to write image data to binary PGM file format(P5)? tommy_chai Programming 0 08-10-2007 08:22
Ball Passing codeoftherobot Rules/Strategy 6 12-01-2004 22:26
