Go to Post Indianagineers! (n.: In-di-ae-nah-jih-nir: any resident of Gary, Indiana, or it's suburbs, who is trained in the use or design of machines or engines, or in other areas such as electrical or chemical technology) - dlavery [more]
Unread 07-02-2009, 15:37
Sauce Sauce is offline
FRC #1245 (Shazbots)
Sauce is an unknown quantity at this point
Lightbulb Autonomous problems
After loading our Autonomous code into the basic robot main, the camera tracks the two colors well, but we cant' seem to get the speed controllers to function, we took the whole of the PID loop code at the bottom of the Servo Camera Example and threw into the Two Color Tracking example, added an algorithm that converts the servo values into motor values and puts it into tank drive, we see values being placed into the tank dirve VI, but speed controllers don't respond, I'd give you a picture, but I don't have one at my house.
Unread 07-02-2009, 15:40
Re: Autonomous problems
Probe the values being sent to the motors. If the math isn't right and you are mostly sending small numbers near zero, that would be the problem. If you are sending numbers that are reasonable and the motors aren't moving, look at the watchdog or wiring issues.
Greg McKaskle
Unread 07-02-2009, 15:42
Watchdog is fine and we are getting values of .6 and -.6, we limited it so we coudl test it in our environment with less risk of serious damage
Unread 07-02-2009, 15:55
If you are sending 0.6 to a motor controller and you aren't getting errors back and the motor isn't running, it is either a wiring or a watchdog issue.
Check for errors from the motor call, and if that doesn't work, verify the module number and channel numbers match how the robot is wired. Also make sure the LED on the motor controller seems right.
Greg McKaskle
Unread 07-02-2009, 15:59
We aren't getting any light change on the controllers... I am almost positive that it's wired correctly but my entire team is working on the bot right so I can't really make sure...
Autonomous Problems Team_486 Programming 1 08-02-2008 13:59
EasyC/IR problems in Autonomous cardinalman86 Programming 2 22-01-2008 15:50
Gyro Autonomous Problems cprogrammer Programming 5 23-03-2007 14:28
Turning problems in Vex autonomous. jamesgecko Programming 3 09-03-2006 16:41
Autonomous and joystick problems sirbleedsalot Programming 3 11-02-2005 00:11
