Go to Post Listen to this FIRST: Thank you - Daniel Brim [more]
Unread 07-02-2009, 15:45
Re: Invalid PWM Channel Index
From the probe, the value in the channel is indeed invalid.
The PWM stuff is used for both servo and motor, and of course drive uses motor. So, one of those opens either has nothing wired to it and it defaults to the invalid channel, or it has a constant wired up with invalid.
Also, make sure you are calling opens and you aren't just typing stuff into a PWM reference.
Greg McKaskle
Unread 07-02-2009, 16:02
Mr.Macdonald Mr.Macdonald is offline
FRC #2272
Mr.Macdonald is an unknown quantity at this point
Could you explain what you mean by:
Is it possible to talk with you or someone from NI over phone or IM
Unread 07-02-2009, 20:49
Actually, the open requires the channel to be wired. Check each Motor open and see that you have the channels wired that you meant to.
If you are using the drive VIs, check those opens. If using servos, check those too.
Finally, the next time you run, make sure the dashboard is open. It will show you if you have errors. I suspect that you have an issue where a channel is already in use, produces an error, and then the refnum is invalid.
Greg McKaskle
Unread 11-02-2009, 19:30
aerophd2001 aerophd2001 is offline
Software Mentor - Team 2366
AKA: Andy
FRC #2366 (Tesla Robotics)
aerophd2001 will become famous soon enough
Preface: I am a Certified LabVIEW Architect.
In our Teleop/Init I've placed a routine that allocates 8 channels in a row (inside a For Loop) to allocate 8 Servos. I'm converting the iteration terminal of the loop to a U8 then typecasting it to the PWMChannel.ctl typedef enum prior to the value entering the Servo/Open.vi. We're receiving the -44037 (PWM Channel is already allocated) error ... but only on the 1st two of the eight channels. The last 6 are allocating just fine and in operation work perfectly.
Any ideas what's going on here?
(Test + Refine Code + Deploy) ^ n
Unread 11-02-2009, 19:50
The servo VIs use the PWM outputs (and are shared between the Jaguar, Victor, Servo, PWM, and Robot Drive libraries). The default code uses PWM 1 and 2 for the Robot Drive Library, could you be trying to reallocate them?
Unread 11-02-2009, 20:09
AKA: Andy
So you're saying that PWM Channels 1 & 2 cannot be used for servos? (or: only 3-10 *can* .. ?)
Unread 11-02-2009, 20:20
You can use PWM channels 1 & 2 for servos, you just have to delete the Robot Drive VIs (or change which PWM channels they use).
Unread 11-02-2009, 20:42
If you look at a digital sidecar, it has a row of PWM connectors. Each connector can be used for motors or servos depending on if they are jumpered. The SW API needs to deal with this HW resource limitation.
So, once you've designated a PWM channel is used for one thing, it is reserved and cannot be reopened for the other purpose. What Joe is pointing out is that the template code already reserves the first couple channels as being for motors. That means that until they are closed, they cannot be opened for servos and will return an error.
Greg McKaskle
Unread 11-02-2009, 23:23
AKA: Andy
I found the source of the error. It was all the way back in the Begin.vi within Robot Main.vi. I didn't know (until I just now found it) that the main drive motors are being initialized within Begin.vi. I'm making my modifications now and will test tomorrow afternoon when we continue with our testing.
Invalid Address Farnak Programming 4 17-04-2008 19:09
Invalid Address team 803 Programming 20 21-02-2006 09:10
2005 Robot Picture Index Gasperini Robot Showcase 9 09-04-2005 13:06
IRI popularity index Joe Ross Fantasy FIRST 5 03-07-2004 12:36
Metal/Materials/Tools Source Index dlavery Technical Discussion 0 12-01-2002 00:36
