Go to Post So is this how cRIOs are made? - pSYeNCe [more]
Unread 07-02-2009, 17:02
morganh2550's Avatar
morganh2550 morganh2550 is offline
Actuationator
FRC #2087 (BFG)
Team Role: Electrical
morganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nicemorganh2550 is just really nice
Exclamation cuting plexi
what is the most efficient way to cut plexi-glass
Unread 07-02-2009, 17:09
AKA: Dr. Brooks
no team (WRRF)
Re: cuting plexi
A table saw with a non-ferrous blade.
After that, a jig saw with some lubricant
to avoid melting from the friction.
Eugene
Unread 07-02-2009, 17:25
meastman meastman is offline
FRC #1245
meastman is an unknown quantity at this point
Re: cuting plexi
A band saw works too.
Unread 07-02-2009, 18:26
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
Re: cuting plexi
If it's really thin plexiglas, I think you can score it and then carefully snap it. Look it up on google for more instructions.
"we don't build robots, we build people"
Unread 07-02-2009, 18:48
parser parser is offline
AKA: Parsia Keynejad
FRC #0840 (ART)
parser is an unknown quantity at this point
Re: cuting plexi
The same blades you use for wood will work well but, you can buy specialty bits to cut plexi which work really nicely.
Unread 07-02-2009, 19:11
ironbears ironbears is offline
Alex@854
AKA: Alex
FRC #0854 (Ironbears Team 854)
ironbears is on a distinguished road
Re: cuting plexi
depends how much you care.
a carbide table saw blade works great for making strips.
metal bandsaw blade nice and slow works.
if milling it use a little coolant. just regular 40:1 mixture
if its polycarbonate scoring may not work
Iron Bears Team 854
Rookie Year 2002
2008 ON Xerox Creativity
2007 WAT Rockwell Automation Innovation in Control
2007 WAT Regional Finalist
2007 ON Motorola Quality
2007 ON Regional Finalist
2006 ON Motorola Quality
2005 ON RadioShack Innovation in Control Award
2005 WAT RadioShack Innovation in Control Award
2003 ON Delphi "Driving Tomorrow's Technology"
2005 The Championship Event (4/21/2005 - 4/23/2005)
2003 The Championship Event (4/10/2003 - 4/12/2003)
Unread 07-02-2009, 19:15
vivek16's Avatar
AKA: vivek
Re: cuting plexi
If it's polycarbonate, you can use a jump press (I've only ever cut 1/16" thick polycarbonate on a jump press, I'm not sure how much thicker you can get before it doesn't work as well.
Unread 07-02-2009, 19:37
CraigHickman
Posts: n/a
Re: cuting plexi
I suggest with a properly applied cutting implement.
I'd love to help, but we need a bit more info. What thickness? What kind of cuts? What type of Plexiglass, or is this actually Polycarbonate/Acrylic?
Unread 07-02-2009, 20:34
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: cuting plexi
My Favorite way to cut plexiglass is with a table saw. I've done it with a vertical bandsaw and a guide to keep it straight but the plexiglass may crack if it gets too jumpy.
As for Lexan (Polycarb), a Table Saw is still best for Straight cuts and I Like a vertical band saw the best for any kind of a technical cut.
If you're in a pinch and you need to cut Lexan (polycarb) you can use a Circular Saw. I'd only cut this way as a last resort because it gets pretty dangerous.
-Dustin Benedict
Unread 07-02-2009, 20:37
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: cuting plexi
If it is thin, like 1/16 or smaller, shears work. They are slow but very straight.
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 07-02-2009, 20:41
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: cuting plexi
Also, leave the paper backing on it while you're cutting it!!!!
This is important to avoid cracking/splintering for whatever method you use to cut it if you're using a saw type method.
If you're using a heated up piece of wire (which is possible for both cutting & bending - on a very low heat setting to avoid burning too much), then it would probably be better to take the paper off first.
Unread 07-02-2009, 22:41
Pumagrif's Avatar
Pumagrif Pumagrif is offline
Crazy 204 Mentor
AKA: Geoff
FRC #0204 (Eastern Robotic Vikings)
Pumagrif is an unknown quantity at this point
Re: cuting plexi
Leave the film on the plexi glass, use a small tooth ratio blade, and also cut slowly so it will not fuse back together.
For a successful technology, reality must take precedence over public relations, for Nature cannot be fooled.
Unread 08-02-2009, 01:23
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Re: cuting plexi
Don't use a hand saw. I had to do that at a regional once and it was not a good idea.
Also, when you cut plexi with a power blade. Realize that the plexi will send off little fragments of the glass. Might be a good idea to have sleeves on when cutting. (Just make sure the sleeves can't get caught or anything.)
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 08-02-2009, 03:58
BurtGummer BurtGummer is offline
Electrical/Mechanical/Programming
FRC #3020
BurtGummer will become famous soon enoughBurtGummer will become famous soon enough
Re: cuting plexi
We have been using jigsaws. Not the best, but they work. Gotta use coarse blades though, or else you will have melting problems.
Unread 08-02-2009, 04:38
NickE's Avatar
NickE NickE is offline
_
Re: cuting plexi
A foot shear works well for 1/8" and thinner polycarbonate.
For thicker polycarb, a circular saw goes fast, but it splinters like mad.
pic: Team 2614's Cracked Plexi SlaminSwimster Extra Discussion 19 18-07-2008 00:10
plexi glass clatek Technical Discussion 13 29-01-2006 13:01
Will plexi-glass work? MathewSmith Technical Discussion 33 08-04-2004 07:17
Plexi-Glass walls Brett W Rules/Strategy 8 21-02-2003 22:44
