Honey, will you tether your soul to mine?
Unread 07-02-2009, 19:47
Re: Axis Cam brightness in LabView
The mask for both of the colors is set pretty wide, so as you noticed, bright orange, red, and magenta will get picked up too. That isn't so bad.
You say the green doesn't look so hot. The best way to determine which parameter is off is to open up the subVI called FindTwoColor. On its panel is a button for debugHSL and an image display which you can mouse over to see individual pixels in HSL. This is off by default because it slows stuff down, but for tuning, turn it on and hover over the pink and green areas. Compare that to the HSL numbers on your top panel.
Ideally the H number is somewhere near the center. It probably needs to be around five or ten from the high or low.
The saturation needs to be above the minimum by ten or so, and the luminance above the minimum by ten or so.
If your light is sufficiently different, you may need to bump the numbers a little. You can do it while the VI runs. The other option is to turn on more lights or move to a place with more even lighting.
I would really like to hear which parameter was off and how much you had to change it to work.
Greg McKaskle
Axis Camera w/ Labview problem lamoreaux2198 Technical Discussion 2 14-01-2009 04:38
Axis Camera Programming in Labview Striker_27 NI LabVIEW 10 09-01-2009 19:19
Getting Live Axis cam feed popo308 Programming 7 09-01-2009 19:14
Axis cam problem keehun Programming 8 07-01-2009 11:32
Anyone know how to get a live video feed from your axis cam? Jazonk FRC Control System 7 03-01-2009 20:08
