Go to Post Robotics is better than Football. Robotics > Football !!! - Arkorobotics [more]
Unread 07-02-2009, 20:53
Re: Directly connect to camera
192.168.0.90 is correct. But the camera has to be on the same network as the computer. You won't be able to connect to it through the cRIO.
Cannot Connect to Axis Camera Wirelessly computerish Technical Discussion 4 11-01-2009 19:19
Can Relay Outputs Directly Drive LEDS ? (for testing) de_ Control System 7 11-04-2008 15:13
Connecting 7.2V (directly) to camera scottmso Programming 15 14-01-2006 23:13
How do i connect the camera for testing? naor52 Programming 1 12-01-2006 01:11
