Go to Post I am all for high school sports, but as Dean continually preaches, we sometimes are not putting enough emphases in the right places. - Bill Beatty [more]
Unread 07-02-2009, 19:05
Mr. E Mr. E is offline
Its physics or stamp collecting
FRC #1883
Mr. E is an unknown quantity at this point
jaguars suddenly not working
We were trying to program a bunch of separate buttons, and the programing part was going okay. We were troubleshooting and stuff, but then a problem occurred. The buttons were showing up, (the spikes were changing color,) but they were looping or something. Whenever a button was pushed, the spike light flashed like crazy. So, I altered the program to try to get it so that when a button was pushed, the spike light was continuously on, and now the I have blinking, disabled jaguars and nothing is working. I put the program back to the "semi-working" state and tried restarting everything, but it still doesn't work. Does anyone have an idea as to what the problem could be? The RSL light is solid.
Unread 07-02-2009, 21:09
Re: jaguars suddenly not working
The problem could be one of a hundred or more things. Without knowing more about your code, or at least what you want your code to do, anything I could suggest would just be a guess.
My first guess: you want your button to turn on the relay on the first press, and turn it off again on the next press. Is that correct?
Jaguars working with 2.4 Ghz R/C NOV8R Technical Discussion 0 09-01-2009 16:15
p2 not working? Lone_Wolf92c Programming 5 22-02-2008 08:49
IR Board Not Working (But NOT Fried) itsme Electrical 2 18-02-2008 06:11
gyro not working johnsmith11111 Programming 4 14-02-2008 17:13
Gyro not working 1594code Programming 2 12-02-2008 18:16
