Go to Post In the end, we were successful, but the tale is one of such stupidity that it should be engraved in drool upon a failed math test. - AmLameBro [more]
Unread 07-02-2009, 21:10
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
Creating a Delay in Actuating a Solenoid
We have two Pneumatic Solenoids that are actuated using the trigger button on either joystick. One solenoid controls a gate and the other solenoid controls a platform that can be tilted.
The goal is that we lower the gate about 500ms (1/2 sec) before the platform tilts.
Getting both solenoids to actuate at the same time is easy enough. However, getting one to actuate, then wait for 500ms and then actuate the second one is a more difficult problem.
If anyone has a starting point here we could use the help.
Sean
Unread 07-02-2009, 21:51
Re: Creating a Delay in Actuating a Solenoid
Chain the error output of the first solenoid set to the error input of a "delay and feed" watchdog, then chain the watchdog's error output to the error input of the second solenoid set. That's a simple way to do sequencing with delays.
Is that a good starting point?
Unread 07-02-2009, 22:19
TimeOut's Avatar
AKA: Sean Kelly
Yep, I'll give that a try when we hit the bot again on Monday.
Thanks!
Sean
Unread 16-02-2010, 19:19
Team1268 Team1268 is offline
FRC #1268
Team1268 is an unknown quantity at this point
Hi Alan and Timeout...
We are working with a similar programming senario... I am new to the idea of a "watchdog."
We want to program a button to trigger the first solenoid, wait two seconds, and trigger a second solenoid. When we wired up the watchdog as previously described, it loops like we got caught in an infinate loop.
I am not at school and cannot send a screenshoot right now. but I will post it ASAP. Is their another way to sequence besides using watchdogs in LV?
Unread 17-02-2010, 02:38
Lumit Lumit is offline
FRC #2521
Lumit is an unknown quantity at this point
The delay and feed watchdog vi will freeze your motor control... This is for teleop, correct?
teleop is in a loop, and delays will shut down all control until it is done.
You'll probably want a state machine: http://frcmastery.com/try-me/state-machines/
Unread 20-02-2010, 23:28
FRC #1268
Thanks for everyone's help... the frcmastery tutorial was key!
Delay jasonpeinko Programming 8 18-01-2008 15:56
Delay Function Slick Programming 6 01-03-2007 22:56
EDU-MINI RC Solenoid Switching times and Delay time? Generalx5 Technical Discussion 0 25-01-2007 01:32
Delay Gal Longin Programming 1 09-12-2004 10:37
Creating no pressure with double solenoid? Combat Chuck Pneumatics 7 29-02-2004 22:45
