Re: Reboot robot every download?
None of my code ends up being executed. For example, my drive train? Nothing. My camera search pattern? Nada. Joystick triggers? Nihil. However, if I reboot the robot and change none of my code, it works like a charm.
Have you tried probing the joystick axes? The camera servos? The inputs to the motor drive? Find out how far things do work, and then we can try to figure out why they stop working at that point. |
Ok, after further investigation the motors were the ones that did not respond without a reboot. I have lately flashed the v11 code to the robot, and it is now working flawlessly. Issue closed?
| cRIO loses code on reboot? | boris | FRC Control System | 1 | 30-01-2009 10:42 |
| Run Kernel Task w/o reboot | byteit101 | Programming | 4 | 12-01-2009 12:08 |
| 2006 Robot Code Download | Chris_Elston | Programming | 2 | 05-05-2006 10:42 |
| Robot Stats on Every Robot at Championships | SpaceOsc | Scouting | 8 | 13-04-2002 11:55 |
| Robot Stats on Every Robot at Championships | SpaceOsc | Championship Event | 0 | 08-04-2002 19:20 |
