Re: Creating a Delay in Actuating a Solenoid
Chain the error output of the first solenoid set to the error input of a "delay and feed" watchdog, then chain the watchdog's error output to the error input of the second solenoid set. That's a simple way to do sequencing with delays.
Is that a good starting point? |
Yep, I'll give that a try when we hit the bot again on Monday.
Thanks! Sean |
Hi Alan and Timeout...
We are working with a similar programming senario... I am new to the idea of a "watchdog." We want to program a button to trigger the first solenoid, wait two seconds, and trigger a second solenoid. When we wired up the watchdog as previously described, it loops like we got caught in an infinate loop. I am not at school and cannot send a screenshoot right now. but I will post it ASAP. Is their another way to sequence besides using watchdogs in LV? |
The delay and feed watchdog vi will freeze your motor control... This is for teleop, correct?
teleop is in a loop, and delays will shut down all control until it is done. You'll probably want a state machine: http://frcmastery.com/try-me/state-machines/ |
Thanks for everyone's help... the frcmastery tutorial was key!
| Delay | jasonpeinko | Programming | 8 | 18-01-2008 15:56 |
| Delay Function | Slick | Programming | 6 | 01-03-2007 22:56 |
| EDU-MINI RC Solenoid Switching times and Delay time? | Generalx5 | Technical Discussion | 0 | 25-01-2007 01:32 |
| Delay | Gal Longin | Programming | 1 | 09-12-2004 10:37 |
| Creating no pressure with double solenoid? | Combat Chuck | Pneumatics | 7 | 29-02-2004 22:45 |
