Go to Post Wait - a single message outlining the vast majority of where to find controls stuff? Goodness. What will they think of next. - Tom Line [more]
Unread 07-02-2009, 21:58
Re: Reboot robot every download?
Originally Posted by lostkhaos View Post
None of my code ends up being executed. For example, my drive train? Nothing. My camera search pattern? Nada. Joystick triggers? Nihil. However, if I reboot the robot and change none of my code, it works like a charm.
None of your code? So far, your description just indicates that the outputs are not working, but you haven't said anything to help determine where the problem lies.
Have you tried probing the joystick axes? The camera servos? The inputs to the motor drive? Find out how far things do work, and then we can try to figure out why they stop working at that point.
Unread 13-02-2009, 14:35
lostkhaos lostkhaos is offline
FRC #1307
lostkhaos is an unknown quantity at this point
Ok, after further investigation the motors were the ones that did not respond without a reboot. I have lately flashed the v11 code to the robot, and it is now working flawlessly. Issue closed?
cRIO loses code on reboot? boris FRC Control System 1 30-01-2009 10:42
Run Kernel Task w/o reboot byteit101 Programming 4 12-01-2009 12:08
2006 Robot Code Download Chris_Elston Programming 2 05-05-2006 10:42
Robot Stats on Every Robot at Championships SpaceOsc Scouting 8 13-04-2002 11:55
Robot Stats on Every Robot at Championships SpaceOsc Championship Event 0 08-04-2002 19:20
