Go to Post Having someone with as much mainstream appeal as will.i.am is a great strategy to draw large amounts of attention to a program that has been relatively hidden to the masses. - Karthik [more]
Unread 07-02-2009, 21:44
bobwrit's Avatar
bobwrit bobwrit is offline
//No Comment
AKA: ...
FRC #1977 (Loveland High Robotics)
bobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nicebobwrit is just really nice
DIO Signal, Channel, slot, and Vex UltraSonic
Ok, I'm trying to wire up a 8 bit switch up to the DIO of a sidecard that is attached to cRio module 4. The switch is in DIO position 1 & 2. The question I have is, when the context help refers to channel, and slot, what are they reffering to? Also, when we are using the get DIO value vi, it only returns a boolen, what a switch is suposed to do is return a value, right? So, how do I get the value?
Another question we have is, we have a vex ultrasonic sensor atached to DIO 3 & 4, and when we use the get range vi that labveiw supplies(after opening it of course), it always returns 0 in. We have the ultrasonic open outside of our teleop loop & case and the deviceref connect directly to the get range vi within the loop & case. When we turn execution highlighting on, the error wire is returning ok at all points before and after the get range vi. Any help?
FRC Team 1977 Alumni
Has Attended:2008 Colorado regional
2009 Colorado Kickoff
2009 Colorado Regional
2010 Colorado Kickoff
2010 Colorado Regional
The most exciting phrase to hear in science, the one that heralds new discoveries, is not "Eureka!"(I found it!), but rather, "Hmm.... That's funny" ---Isaac Asimov
Chance favors the prepared mind ---Louis Pasteur
And you can tell me, that I can't make a diffrence because I'm just one, but one is all it takes to start it. And you can tell me, that I can't change the world because I'm too young, but I wont stand here and be your target. ---FM Static
Unread 07-02-2009, 21:51
Kahn! Kahn! is offline
FRC #1379
Kahn! is an unknown quantity at this point
Re: DIO Signal, Channel, slot, and Vex UltraSonic
The channel is where on the module you are, basically. There are 16 (right? or close to it) digital channels on each sidecar. They are numbered.
Slot is the slot on the CRio your sidecar is hooked up to.
Unread 07-02-2009, 22:06
TimeOut's Avatar
TimeOut TimeOut is offline
AKA: Sean Kelly
FRC #0499 (The Toltechs)
TimeOut is on a distinguished road
Re: DIO Signal, Channel, and slot
Bit switches: You need to manually determine the value of the switch. For instance, if you are using just two bits then it follows:
Bit one Bit two
False False = 0
True False = 1
False True = 2
True True = 3
something like this. The switches are your DIO inputs.
The slot is the module, you probably don't really need to set it and just use the default (module 4). For the channel, right click on the terminal select CREATE then select CONSTANT and select the proper DIO channel (1 or 2?)
I've attached some simple logic for 4 bits. There is probably a much more effecient way to do this in LabVIEW than this; but it does work
Sean
Unread 07-02-2009, 22:12
TimeOut's Avatar
AKA: Sean Kelly
The VEX Range finder works my 'Pinging' and then getting the result based on the amount of time it takes for the Ping to return. So, the process might actually be use the Ping then use the Get Range.
Sean
Unread 07-02-2009, 22:14
bobwrit's Avatar
//No Comment
AKA: ...
Sean
We've tried that as well and that didn't work. We think the GetRange function has the ping function somewhere in it.
Unread 07-02-2009, 22:29
TimeOut's Avatar
AKA: Sean Kelly
I think the ping.vi must be called. Looking inside the GetRange.vi I don't see anything that is causing the Ping to occurr.
Take a look at this post and see if it helps/hurts.
http://www.chiefdelphi.com/forums/sh...RIO+ultrasonic
Sean
Unread 07-02-2009, 22:34
bobwrit's Avatar
//No Comment
AKA: ...
When we had ping.vi in the code, the execution order for the sensor was, open, wired to ping, wired to ultrasonic. There is a brach in the wire in between the case and the loop whic leads to the close.vi. We are using update 3 by the way.
Signal wire gauge and color. sparrowkc Electrical 4 10-03-2010 19:51
DIO not working in autonomous. adamdb NI LabVIEW 10 12-02-2009 01:23
Open motor reference on Slot 6 DIO Module trilogy2826 NI LabVIEW 2 27-01-2009 08:42
Using DIO pin 14 as timer source? Jared Russell Programming 1 12-02-2006 00:02
Robots and the Learning Channel.... archiver 2000 0 24-06-2002 00:16
