Go to Post This is a pure blooded, man and machine versus man and machine, brain versus brain, driving skill challenge. - Andy Grady [more]
Unread 08-02-2009, 01:19
JohnBoucher JohnBoucher is offline
Blue Shirt
FRC #0237
JohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond reputeJohnBoucher has a reputation beyond repute
pic: Sidecar problem
Unread 08-02-2009, 01:21
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Re: pic: Sidecar problem
Technically that would be a solder reflow problem, not a wave-flow problem. Wave soldering is used to solder through-hole parts, whereas reflow soldering is used for surface-mount parts.
Looks like they may have a problem with their paste mask?
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 08-02-2009, 04:08
See http://forums.usfirst.org/showthread.php?t=10621
Unread 08-02-2009, 08:15
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
I don't think that FIRST wants you to return your sidecars if that missing/loose capacitor is the only issue. The conformal coating on the board should keep any loose parts or metal filings (within reason) of causing any issues.
Did you have any other issues with the sidecar? Did it work fine otherwise?
Russ
Unread 08-02-2009, 08:49
Blue Shirt
FRC #0237
It appears to be the only issue. Is C6 necessary and does removing it affect anything?
Unread 08-02-2009, 10:04
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Kate from FIRST stated in the aforementioned Q&A link:
Originally Posted by Kate
It's confirmed. The C6 capacitor is essentially redundant and therefore unnecessary. The remaining C4 capacitor has sufficient specifications to provide filtering for the 6V servo power supply. It may provide a slight reduction in noise in the 6V servo power supply but we have been unable to detect any negative effects via testing at FIRST HQ.
Fortunately, the Digital Sidecar has conformal coat and, as a result, a loose C6 capacitor will NOT result in any electrical shorts within the module.
We do recommend that teams open the case and remove the loose component.
http://forums.usfirst.org/showpost.p...04&postcount=8
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
Unread 08-02-2009, 12:31
falconmaster's Avatar
falconmaster falconmaster is offline
AKA: Ledge
FRC #0842 (Falcon Robotics)
falconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond reputefalconmaster has a reputation beyond repute
Send a message via MSN to falconmaster
Between two teams and ourselves we have 4 side cars that do not work. We were a beta test team and we are on our spare side car. We have made no wiring changes and the second car is working fine. The first side car worked fine for 4 weeks. We suspect a quality control or faulty design. We are going to buy two more because we are expecting them to go out. We are watching all the threads about this
Faridodin "Fredi" Lajvardi KD7WKD
Sidecar Debug NinjaSpawn94 NI LabVIEW 6 07-02-2009 10:48
Digital Sidecar Problems cabbagekid2 FRC Control System 13 31-01-2009 17:23
Digital Sidecar Resistor NinJA999 Electrical 5 30-01-2009 19:53
connecting Jaguar to Sidecar Lakedaimon Electrical 2 15-12-2008 01:04
Missing Standoffs on Sidecar psyco_klown Electrical 3 03-12-2008 19:40
