Go to Post Dave Lavery, Lou Rosanio and Karthik are all Woodie Flowers winners this year. So mentors it seems like if ya want the WFA it might be a good idea to put on a kilt :) - Kyle [more]
Unread 08-02-2009, 12:20
vb_master's Avatar
vb_master vb_master is offline
FRC #2428
vb_master is an unknown quantity at this point
TwoColorTrackDemo Vertical Sweep
Hey everyone. I am the only programmer on my team and I am having problems with the TwoColorTrackDemo project. The camera will lock onto our colors and track them, but it will not move the camera up or down vertically when the colors are moved up and down. It only stays in the normalized positions, with seemingly random shifts up and down. Uncommenting
incrementV = verticalPosition - verticalDestination;
and commenting out the other one seemed to have no effects on the vertical sweep.
Horizontal sweeping works fine, however.
Any suggestions of how to fix this would be greatly appreciated.
The servos are in their correct ports and are recieving power. The camera is of course set up correctly.
Unread 08-02-2009, 12:50
Re: TwoColorTrackDemo Vertical Sweep
If you mounted your camera upside down or made your gimbal the opposite of the way the code expected, you wouldn't see random movements, but opposite movements. This would quickly cause the camera to lose the target.
I think it is pretty easy to swap the movements in the C code.
Greg McKaskle
problem with TwoColorTrackDemo-v2 mahmosh C/C++ 5 20-01-2009 09:30
Team 867 is going to sweep the competition seanl Robot Showcase 10 10-03-2008 17:11
Size of the Pan-Tilt's Sweep? geeknerd99 Programming 1 27-01-2006 20:25
Vertical bar interaction Madison Rules/Strategy 5 10-01-2004 16:22
vertical conveyor belt ahecht Technical Discussion 3 15-02-2002 16:16
