Go to Post Instead of "Team XXXX graciously accepts" how about just a big "yeaaaahhhhh!" ? - sanddrag [more]
Unread 08-02-2009, 10:16
oddjob oddjob is offline
oddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to beholdoddjob is a splendid one to behold
HiTechnic compass - reading 65535?
Is this how to use the HiTechnic compass?
  HiTechnicCompass *m_compass;
  float CompassAngle;
  m_compass = new HiTechnicCompass(4); // slot 4
  CompassAngle = m_compass->GetAngle();
The CompassAngle readings are always 65535.0. We checked the cable continuity from the I2C connector on the sidecar to the compass module and it seems ok. See anything wrong?
Unread 08-02-2009, 12:24
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: HiTechnic compass - reading 65535?
That looks correct. I looked at some of my compass test code, and I didn't have to do anything else. I wrote my compass code pre-season and I was using an older version of WPILib, so it may have changed since then.
Do you have another compass and cable to test with? Did you try your other DSC?
Eric Haskins KC9JVH
Unread 08-02-2009, 17:39
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
do you know because of a printf?
we had a wierd output and it was because it was
printf("%i\n", floatvalue);
when it should have been
printf("%f\n", floatvalue);
Watchdog.Kill();
Unread 08-02-2009, 22:44
Thanks for the replies. We replaced the cable with another and the problem went away, so it was a bad cable. The code does work and the compass is working well.
Compass tilt error knine143 Sensors 2 29-05-2008 07:58
Gyro Compass Nathan Programming 5 16-01-2008 14:55
I2C Digital Compass Programming CyberWolf_22 Programming 7 03-01-2005 00:20
Political Compass Joshua May Chit-Chat 11 01-10-2004 22:32
Compass/direction sensor Frank(Aflak) Technical Discussion 10 06-04-2003 09:18
