Go to Post If we can transform our culture to the point where girls swoon over guys as they pull their dremel off their belt and carve some speed holes in a smooth fluid motion, I think FIRST is half way to its goal. When we get the guys to swoon over the girls for their hot moves on the 5-axis, we have won. - EricVanWyk [more]
Unread 08-02-2009, 12:23
mcristina444 mcristina444 is offline
FRC #2078 (Robotic Ooze)
mcristina444 is an unknown quantity at this point
Exclamation labview:what is the joystick axis?
in labview i want to have the robot control speed not going in a linear line is want to to have more control at a lower speed. so i came up with the equasion : x axis squared/max input.. also i would do this same equasion with the y axis. the only thing that i cant find is the max input from the controller. is it 256 or 128? please help.
Unread 08-02-2009, 12:52
Re: labview:what is the joystick axis?
mabe it is also called joystick axis output??
Unread 08-02-2009, 13:02
It looks to me like the numbers are scaled between -1 and 1. If I remember right, the Y axis may seem backwards at first. pushing forwards is negative, pulling back is positive. HID must have been defined by a pilot.
Greg McKaskle
Unread 08-02-2009, 13:06
so it isnot -158 to 158. or 0 to 256?
Unread 08-02-2009, 13:26
Here is the full story. The values returned to the OS according to the HID standard are 16 bits, or -32k to 32k. To be send from DS to robot, they were scaled to -128 to 127.
Finally, to simplify the math and make things more consistent, most values to and from most I/O on the robot is in the range of -1 to 1 or 0 to 1. They are floating point numbers so that when the joystick is pushed half way it reads half, or 0.5. If you want it scaled back to any other range, just multiply.
Greg McKaskle
Reversing the joystick axis JBotAlan Programming 3 09-02-2005 19:47
Tri-axis Analog Joystick KVermilion Control System 5 19-01-2005 00:24
pwm outputs vs. joystick y-axis stephenthe1 Programming 4 01-12-2004 17:29
Inverting Y axis on joystick FormatteD_C Programming 7 24-02-2004 16:56
switching joystick axis????? team222badbrad Technical Discussion 9 16-01-2002 23:07
