Go to Post Never underestimate the power of curious and impatient FIRSTers ;) - kpugh [more]
Unread 08-02-2009, 14:42
PWHSrobotics PWHSrobotics is offline
PWHSrobotics is an unknown quantity at this point
Between Rounds
Will we be able to recompile code/tweak code between rounds of the competition? (practice vs competition rounds, etc? )
Unread 08-02-2009, 14:50
Re: Between Rounds
Between matches, even. The only rules on work at competitions are that you have to work on-site or at a facility that all teams can use while the pit is open. No removing parts overnight. See <R27>. (There are some other rules as well, governing what type of work you can do/tools you can use--see Section 3. Last I checked, programming doesn't violate any of those, though.)
Unread 08-02-2009, 15:31
pentau pentau is offline
AKA: Will
FRC #0449 (Blair Robot Project)
pentau is a glorious beacon of lightpentau is a glorious beacon of lightpentau is a glorious beacon of lightpentau is a glorious beacon of lightpentau is a glorious beacon of light
Send a message via AIM to pentau
Re: Between Rounds
Yes, you can. However, I would recommend against it unless absolutely necessary because our team has had some troubles in the past with code downloads at the last minute.
Unread 08-02-2009, 17:02
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Between Rounds
Be sure you test your new code on your robot before you decide to go with it in competition. I've seen robots do things that no one expected. Sometimes the surprises weren't good.
(since 2004)
Unread 08-02-2009, 17:21
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: Between Rounds
I can vouch for that.
I've had autonomous modes that spun in circles, went backwards into the drivers wall, or ran full speed into the far drivers wall. The refs really didn't like that last one...
Eric Haskins KC9JVH
Unread 08-02-2009, 22:24
AlexD744 AlexD744 is offline
FRC #0744 (744 Shark Attack)
AlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond reputeAlexD744 has a reputation beyond repute
Re: Between Rounds
Usually we don't get a decent autonomous until post-season. And at mission mayhem our wires got crossed and we controlled pink's roccobot. At the end of autonomous pink was at next to a rack at we hadn't moved because something went wrong with our autonomous. So we start going forward and lifting our arm. That lifted their arm while going full speed ahead. So they get caught. When trying to release themselves they were going in reverse and so our robot was slamming against the alliance station wall. We were going forward almost flipping them. So we cut off and they got controll of their robot. Surprisingly we won that match because pink hurdled about 5 times after that.
p.s. We usually don't get completedly programmed until the competition.
Practice Rounds = First Four Rounds...any qualms? Jessica Boucher Regional Competitions 9 21-03-2004 20:24
Elim Rounds Andy144 Rules/Strategy 2 05-01-2003 11:42
Elimination Rounds Jeff Rodriguez Rules/Strategy 15 05-01-2003 11:33
Elimination Rounds vs. Qualifying Rounds archiver 2000 1 23-06-2002 22:43
Practice Rounds?? archiver 1999 6 23-06-2002 22:31
