Go to Post Is it January yet?? - Kevin Kolodziej [more]
Unread 07-02-2009, 18:06
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
myRobot.TankDrive errors
when our team uses myRobot.TankDrive(0.3, 0.3), wheel 1 turns correctly, other wheel barely at all, and when we use myRobot.TankDrive(-0.3,-0.3), wheel 1 barely turns, while the other turns correctly. Is anyone else having this problem?
We are using Victors, and when we set them directly, it works fine, even if we declare them as jaguars.
Watchdog.Kill();
Unread 07-02-2009, 23:02
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Re: myRobot.TankDrive errors
Hi,
I can't answer your question but I think you should copy and paste a few more lines of your code to get a good answer from someone else.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 08-02-2009, 02:36
Chief Pride's Avatar
Chief Pride Chief Pride is offline
&lt;3
AKA: James Kiefer
Chief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond reputeChief Pride has a reputation beyond repute
Also, make sure the digital side car IS PLUGGED IN. We had this problem when I assumed the DSC only needed a power cable for servos. It needs it for victors aswell.
Unread 08-02-2009, 09:08
byteit101's Avatar
that is all, if we have a simple program, myRobot = new RobotDrive(1,2) stick = new Joystick(1), and watchdog diabled, the Teleop looks like this
while(IsOperatorControl())
if (stick->GetTrigger())
 myRobot->TankDrive(0.3,0.3);
else
 myRobot->TankDrive(-0.3,-0.3);
this is only prevalent at speeds of -.45 to .45
Watchdog.Kill();
Unread 08-02-2009, 11:11
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Calibrating your Victors may help as well.
It sounds like your Victor centre-points are different from each other.
You can check to see if they're out of calibration with each other by measuring the voltage being applied to each motor when running. They should be close.
Hold down the reset button until the LED beings flashing red and green. Apply PWM signal full-forward, then full-backwards, then neutral. Wait for the LEDs to stop flashing.
-Shawn T. Lim...
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 08-02-2009, 17:37
byteit101's Avatar
Thanks! that seemed to work!
Watchdog.Kill();
WindRiver Errors ExarKun666 C/C++ 7 04-03-2009 20:32
Errors on LabVIEW PHSRobotics NI LabVIEW 12 11-02-2009 10:00
WindRiver "TankDrive" KRibordy C/C++ 4 13-01-2009 18:13
Makefile Errors neutrino15 Programming 1 29-01-2008 15:45
CAMERA ERRORS!!!!!!!!!!!! Hershey Technical Discussion 0 21-01-2005 18:59
