Go to Post Consider that the 12V from your robot isn't any different from the 12V from your car's cigarette lighter. (Err... sorry... that's "power port" these days, thank goodness.) - dtengineering [more]
Unread 08-02-2009, 15:57
finman's Avatar
finman finman is offline
Programmer
AKA: Chris Finley
FRC #0888 (Robotiators)
finman is an unknown quantity at this point
drivers station digital input trouble
on our control board, we have several switches that i have wired to digital inputs on the drivers station console. in labview i have made an indicator light that should light when the circuit is open. when the circuit is closed, the light goes off as it should, but when it is open, it flashes on and off. even when i connect a pwm cable with NOTHING on the opposite end, the light still continues to flash. any ideas why this is happening?
"Red goes to black, right guys?" ~Mike Mascaro: Our Fearless Leader
Unread 08-02-2009, 16:16
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Re: drivers station digital input trouble
How are your inputs wired? The inputs of the drivers station contain no pull up or pull downs so you have to wire them yourself or you might get some in between state when they are open.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
Unread 08-02-2009, 20:30
BitTwiddler's Avatar
BitTwiddler BitTwiddler is offline
electronics/programming mentor
AKA: Mr Tanguay
FRC #1726 (N.E.R.D.S.)
BitTwiddler is on a distinguished road
Here's how I've been telling our electronics team to wire up switches connected to the Driver Station digital inputs.
It shows how to hook it up when your switch has two terminals or three terminals.
Normal convention is that when a switch is in the "off" position, the signal line provides +5 volts and ground when "on" so you may see the opposite of what you expect in your programming but its usually easy to invert the sense of the switch.
Name:	Driver Station switch wiring.jpg
Unread 08-02-2009, 22:02
Wylie99998 Wylie99998 is offline
FRC #0871
Wylie99998 is an unknown quantity at this point
something similar happened to us : [ we found that using pullup resisters on our buttons that were connected to the digital inputs fixed the problem
Unread 09-02-2009, 07:22
Chris,
Without the pullup resistors, the high input impedance of the devices used, can respond to anything including your hand, a closeby radio station, even a CFL or a plasma TV screen.
Unread 10-02-2009, 22:43
Andrew Y.'s Avatar
Andrew Y. Andrew Y. is offline
FunYun
AKA: Andrew Yun
FRC #2415
Andrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud ofAndrew Y. has much to be proud of
is there a special resistor i need to use or will any 1k resistor do?
Unread 10-02-2009, 23:46
Imaginary Friend
AKA: Kevin Li
Team Role: Student
I've been using 10k ohms. 1kohms should be ok.
Kevin Li
596 - Sciclones
Unread 11-02-2009, 14:55
finman's Avatar
Programmer
AKA: Chris Finley
we got it, thanks everyone
Unread 15-02-2009, 12:11
kushvp kushvp is offline
FRC #0467 (Shrewsbury Colonials)
kushvp is an unknown quantity at this point
how exactly did you solve your problem? we are have the same issue.
Unread 16-02-2009, 08:06
You must use and external pullup resistor for digital inputs on the DS.
Trouble Reading Drivers Station Digital Inputs Mike Mahar C/C++ 3 03-02-2009 23:37
Drivers Station Magical Current 3DWolf Electrical 5 25-01-2009 21:52
Drivers' Station Camera Feed dhawk085 Technical Discussion 4 25-01-2009 19:12
Flashing Driver Station Digital Input MacGyver1718 FRC Control System 3 15-01-2009 19:22
Interrupt on driver station digital input Nameless Programming 9 04-12-2008 16:55
