Go to Post We can either sit around and complain about what could have been, or we can focus on the upside of what we have and move on. - Vikesrock [more]
Unread 05-02-2009, 18:11
furiousgeorge's Avatar
furiousgeorge furiousgeorge is offline
FRC #3055
furiousgeorge will become famous soon enoughfuriousgeorge will become famous soon enough
cRIO Imaging Tool HELP PLEASE!!!
i'm trying to connect to my cRIO but when i run the imaging tool it says that "no devices can be found" i've tried everything! the router, bridge and all other components of the robot are running fine, and the laptop is connected to the wireless signal. please help me! i don't know what else to do!
Unread 05-02-2009, 19:42
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: cRIO Imaging Tool HELP PLEASE!!!
Connect your cRio to your PC directly using a crossover cable, and set your IP address to 10.0.0.6 subnet 255.0.0.0. Then post your results.
BTW, i tried everything isn't very useful. If you had tried everything you would have fixed it. Its much better to explain just what you have tried.
Eric Haskins KC9JVH
Unread 08-02-2009, 22:44
bls0620's Avatar
bls0620 bls0620 is offline
FRC #0368 (Team Kika Mana)
bls0620 will become famous soon enoughbls0620 will become famous soon enough
Try check your IP first. If this is your first time updating your cRIO, IP address should be 10.0.0.2 with submask of 255.0.0.0
Connect your PC to Driver station. From there driver station should be connected to cRIO directly(I don't recommend using wireless connection when you are updating cRIO image.)
FRC cRIO Imaging Tool furiousgeorge Programming 1 06-02-2009 09:52
cRio Stand-alone Image Tool Vikesrock FRC Control System 3 29-01-2009 19:38
Need help to find a tool, kinda urgent R.C. Technical Discussion 41 12-07-2008 14:44
pic: please help us please mortals CD47-Bot Robot Showcase 5 25-01-2004 11:03
please help us, pretty please :) archiver 2001 0 24-06-2002 03:13
