Go to Post Our thanks does not have to come from their lips. It comes from the finished product that walks across the stage, gets their diploma and moves on to bigger and better things. - Koko Ed [more]
Unread 08-02-2009, 23:17
Re: AI Programming
I think that will indicate which initial location on the field a robot will start in.
Greg McKaskle
Unread 09-02-2009, 07:37
PWHSrobotics PWHSrobotics is offline
PWHSrobotics is an unknown quantity at this point
Re: AI Programming
yep, I know Was just curios as to what number corresponded to which spot. for I can incorporate that into the Auto period.
Unread 09-02-2009, 08:14
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: AI Programming
no, the position related to where your drivers are. Not a lot of use for auto.
Phil Malone
http://www.GEARSinc.org
Unread 09-02-2009, 18:54
Re: AI Programming
yes, but just for kicks, how does the numbering work? Does anyone know? is 1 closes and 3 farthest? or what?
Unread 09-02-2009, 18:59
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: AI Programming
Closest to or farthest from what?
See this thread for more info:
http://forums.usfirst.org/showthread.php?t=11671
Unread 09-02-2009, 20:26
Re: AI Programming
hmm, so I see the R1, R2, R3 etc. My last question is this, do each of those 'Positions' correspond to any particular starting point, or is it all figured out on each alliance and has nothing to do with your robots' starting position
Unread 09-02-2009, 20:27
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: AI Programming
The starting position of your robot will be negotiated with your alliance partners prior to the match and is not related to which driver's station position your team is assigned to.
Unread 09-02-2009, 21:20
Re: AI Programming
ok, thank you very much for everyone's help
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
programming great_one411 General Forum 1 14-02-2003 11:28
programming archiver 2000 2 23-06-2002 22:59
Programming archiver 2000 1 23-06-2002 22:34
