Go to Post Manual labor experience with engineering training is a powerful combination. - N7UJJ [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 08-02-2009, 21:29
wilsonmw04's Avatar
Coach
FRC #1086 (Blue Cheese)
2009 KOP sprocket issues
After some searching, I have not been able to find the problem my team has had this year: our KOP sprockets seem to be incorrectly spaced. I can hear some of the CD members saying, "what the heck does that mean?" Here's what I mean: If you try and wrap a chain around the sprocket, the tooth will hit the roller of the chain every 5-6 teeth. The alignment is correct and the tension is fine. We replaced the sprockets with the sprockets we used last year (AndyMark 26's) and it has worked fine. Is anyone else having the same issues, or are we doing something wrong?
Unread 08-02-2009, 22:24
JamesByrne's Avatar
JamesByrne JamesByrne is offline
FRC #0360 (The revelution)
JamesByrne is on a distinguished road
Re: 2009 KOP sprocket issues
I would find it hard to believe that you are doing something wrong because all you are doing is wrapping chain around a sprocket. I would think that your best bet would be to contact first and get a new one sent to you. The one you have seems to have not been made correctly in manufacturing.
Unread 08-02-2009, 22:38
wilsonmw04's Avatar
Coach
what's weird is that it isn't just one, it's all four. I can't believe that Andymark would be that sloppy in their quality control.
Unread 08-02-2009, 22:42
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
We've found the same thing to be true of some of the #25 aluminum sprockets we got from AndyMark. It seems as if the pitch is just a little off.
--Madison--
...down at the Ozdust!
Unread 08-02-2009, 22:44
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
We noticed the 1-1/8" hole in the center needs to be reamed to 1-1/8" to fit a bearing into it..but we didn't notice the pitch issue....they seem to work. I guess if we looked we might see a problem!
Unread 08-02-2009, 22:49
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
AndyMark is usually pretty good with there stuff, the only problem we ever had was a wobbly toughbox gear. And he sent me a brand new one a few days later.
R.C.
MadTown Robotics Team 1323
Unread 08-02-2009, 23:33
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
To echo Madison, we had an issue with (I believe) 35 pitch sprockets from Andymark in the past as well. I informed Andy of the problem, and he send replacement parts that day, free of charge.
We had the same "chain wrap" issue, the chain would seat in a few teeth just fine, but it would eventually fail to mate with the gear. Seems like the Pitch Diameter is off by the slightest amount.
Again, Andy should be able to take care of your problems. He has always stood behind his product, and has always been prompt with my experiences with him.
Bengineer
Unread 09-02-2009, 00:05
wilsonmw04's Avatar
Coach
Bengineer
Thanks for the replies, folks. I'll be sending AM an email soon. I just wish we noticed the problem before we put the defective parts on the final robot.
Unread 09-02-2009, 01:20
V block V block is offline
FRC #2609
V block is an unknown quantity at this point
We had this same problem with some small sprockets. We found that the set screws that we used were a bit too long. This allowed the chain to ride on top of the set screws and would not allow the chain to seat properly in the sprocket when it was touching the set screw. It was a tough one to find since the chain and sprockets were inside a tube and hard to see. if you have a digital vernier you can measure between every 4 to 6 teeth and compare the measurements all the way around the sprockets. keep looking I'm sure you will find the problem.
Unread 09-02-2009, 10:53
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
I would like to echo the comment from V Block. Check VERY carefully to see if there are ANY obstructions that are preventing the chain from seating fully on the sprocket. The symptom being described fits the case where the pins of the chain are not fully seated, thus causing the effective pitch diameter of the sprocket to increase. This will cause the chain to "skip a tooth" periodically. Two frequent scenarios where this can happen include the protruding set screw mentioned above, and the case where the hub of the sprocket is pressed inside another object (such as a piece of tubing). Sometimes the outer tube is thick enough to cause the side plates of the chain to rest on the tube rather than letter the chain pins seat in the sprocket teeth. The pitch diameter is increased, the pins on the chain are only partially engaged with the sprocket teeth, and the chain will skip. We have been caught by this before - it is an easy thing to overlook.
-dave
Unread 09-02-2009, 11:03
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Yes any little thing can throw off the pitch. We epoxied some AM sprockets to AM hubs and were having the same problem. One of the parents (non-engineer) pointed out that a little epoxy had oozed out and might be causing the problem. Me, the ever knowing engineer, said that little bit of epoxy wouldn't cause a problem. I was wrong.
Possible? Converting KOP 2009 Assemblies to Inventor 2008 7-11number1 CAD 4 02-03-2009 21:42
2009 KoP Double Check JaredSanMiguel Motors 2 14-01-2009 18:12
2009 KOP and Field CAD in Inventor '08/STEP? Travis Hoffman CAD 0 14-01-2009 13:36
Missing Parts in 2009 KOP woogit General Forum 13 04-01-2009 18:18
2009 KOP? excel2474 Kit & Additional Hardware 3 02-10-2008 17:57
