Go to Post What I learned from week-1 is that once again my son has been inspired to the level that he came home after the BAE Systems Granite State FIRST Robotics Regional Competition with the biggest smile I have seen on his face for a long long time. I am truly grateful for that. - FIRST_Parent [more]
Unread 09-02-2009, 03:31
Arcre Arcre is offline
jp
AKA: Jorge
FRC #2504
Arcre is an unknown quantity at this point
Camera on basic framework
How do I use the camera program on the basic framework for labview projects? Do I need to change ips?
Unread 09-02-2009, 09:30
Re: Camera on basic framework
The basic framework has a loop for doing camera stuff. You might want to hook up a display for debugging. Also look at the examples for color tracking, if nothing else to copy a display.
As for the electrical and IP stuff. The camera should be setup using the Camera setup tool according to the directions. Use the orange enet cable between camera and the second cRIO port.
Greg McKaskle
Unread 11-02-2009, 04:17
jp
AKA: Jorge
FRC #2504
Thanks! I will try that, I hope they work.
declaring a servo in begin.vi (advanced framework) Christine_Ilich NI LabVIEW 2 10-02-2009 18:41
Tank Drive with Advanced Framework in Labview finman NI LabVIEW 4 30-01-2009 13:35
FRC Framework Guide Jon236 FRC Control System 0 17-11-2008 18:18
paper: Low Latency Interrupt Framework dcbrown Extra Discussion 5 10-02-2008 15:56
Robot Framework lord Purity Pneumatics 3 21-01-2007 15:57
