Go to Post In the encyclopedia of FIRST under the term Encyclopedia it says - See Joe Ross. - rees2001 [more]
  #121   Spotlight this post!
Unread 06-02-2009, 21:57
synth3tk's Avatar
synth3tk synth3tk is offline
Volunteer / The Blue Alliance
AKA: David Thomas
synth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond reputesynth3tk has a reputation beyond repute
Re: For those who are skeptical about propellers - Team 2526
Just a reminder of how important safety is:
http://chiefdelphi.com/forums/showth...540#post815540
The difference between theory and application is that in theory, theory and application are the same; In application, they are not.
  #122   Spotlight this post!
Unread 07-02-2009, 09:04
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
To any teams that will be using propellers on their robot, be prepared for serious scrutiny from your robot inspectors. I'm still developing the inspector training materials for this particular design element and I'm leaning towards placing a lot of the burden of safety verification on the teams.
Be prepared to defend your design. I would strongly encourage you to bring a "standard finger" to demonstrate general protection.
I would strongly encourage you to calculate the amount of energy stored in your propeller(s) at max speed and determine whether that energy is sufficient to punch through your enclosure. For example, how much energy is required to "rip" a steel wire of diameter X? Maybe you can find such destructive limits on online materials databases.
Bring plenty of documentation to support your design.
Good Luck and BE SAFE!
Russ Beavis
Chief Inspector
  #123   Spotlight this post!
Unread 08-02-2009, 20:39
ChuckDickerson's Avatar
ChuckDickerson ChuckDickerson is offline
FRC #0456 (Siege Robotics)
Russ Beavis
Chief Inspector
Russ,
Thank you very much for addressing the safety issue of propellers here on CD as a warning. I have two questions though:
1) Will the "inspector training materials for this particular design element" be officially released on the FIRST website so that teams will know exactly what they need to be prepared for?
2) Will the "standard finger" be defined? Something like a 3/4"D x 3"L wooden dowel or something? If left to the teams to define I would expect as many different definitions of a "standard finger" as there will be propeller designs. Actually it seems like this should be something that the inspectors provide at inspection rather than the teams if it is to become a "standard" similar to the sizing box or scale.
I ask because the safety considerations for propellers should be taken seriously but the only defined requirements that teams have access to at the current time is the Inspection Checklist. Maybe a section could be added to the checklist covering minimum propeller safety requirements?
  #124   Spotlight this post!
Unread 09-02-2009, 08:00
Chuck,
The standard finger that Russ speaks of is a test fixture used by UL to test fan guards. As I understand it, the device takes into account the distance from the guard to the blade and the size of the openings in the guard as it would pertain to a finger intrusion. As this is a new concept in robot design for First, and has potential safety issues, I am sure that several different disciplines are involved in setting a standard for inspections.
Finger intrusion is only one of those concerns. As have been discussed above, noise, flying debris, robot damge, etc. are all concerns as well.
  #125   Spotlight this post!
Unread 09-02-2009, 08:21
Rex Woodu Rex Woodu is offline
AKA: Eric
FRC #2474 (Excel)
Rex Woodu is an unknown quantity at this point
Dude. Those props are still awesome.
  #126   Spotlight this post!
Unread 10-02-2009, 08:46
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
I look forward to seeing all documentation and substantiation that will support the safety guidelines that Russ will be issuing to the inspectors.
Warren B
Pool Noodles. They're not just for bumpers anymore.
  #127   Spotlight this post!
Unread 10-02-2009, 10:05
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
For those who are curious about how serious fan blade containment is the aerospace industry, check out this certification test performed by Rolls-Royce.
Think of all of the analysis that went into the design of that engine to ensure survival from such a catastrophic failure. The FAA and other aerospace agencies require proof that the design is robust, hence the analysis is backed by this very dramatic (and expensive!) test.
I'd be interested in seeing what came out of the the exhaust of that engine. I bet it wasn't pretty...
BTW, I didn't post this to discourage propeller advocates for robots. I just want them to see what kinds of challenges engineers sometimes encounter.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
  #128   Spotlight this post!
Unread 10-02-2009, 10:16
Collin Fultz's Avatar
Collin Fultz Collin Fultz is offline
no team (IndianaFIRST)
Collin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond reputeCollin Fultz has a reputation beyond repute
You're right. Years of effort goes into these fan designs in the hope that you only have to run this test once.
Some of the coolest testing we do is this test and the bird strike test, which basically involves shooting ducks at an engine running at full power. As was recently proven in NY, it's a good thing we do it. A friend of mine in the test department designed the equipment to do our most recent bird strike test.
As an MC and announcer...I hope the safety restrictions are very tight on prop-driven robots. Otherwise, I'll be announcing from outside.
Collin Fultz
  #129   Spotlight this post!
Unread 10-02-2009, 10:57
As a scorekeeper about three feet from the edge of the arena, who has the added disadvantage of sitting down most of the time and is therefore less mobile, I couldn't agree more.
  #130   Spotlight this post!
Unread 10-02-2009, 11:20
Steigerwald's Avatar
Steigerwald Steigerwald is offline
Questionable???
FRC #0115 (MVRT)
Steigerwald is an unknown quantity at this point
Send a message via AIM to Steigerwald
I agree that that needs some serious protection. Don't underestimate the energy in large diameter spinning objects.
Perhaps you could make a ducted design that turns with the blades. Then you would get more performance, while reducing the chance of pieces coming out of the fan space.
MVRT - Monta Vista Robotics Team #115
2009 Robot El Toro 13
2009 Davis Sacramento Regional Finalist
2009 Davis Sacramento Regional Engineering Inspiration Award
2009 Davis Sacramento Regional Best Website Award
2008 Championship Best Website Award
2008 Davis Sacramento Regional Best Website Award
2008 San Jose Best Website Award
2007 Davis Sacramento Regional Best Website Award
2006 San Jose Best Website Award
  #131   Spotlight this post!
Unread 10-02-2009, 19:13
GaryVoshol's Avatar
Cogito ergo arbitro
Check out the protection requirements in Team Update 11.
(since 2004)
  #132   Spotlight this post!
Unread 10-02-2009, 20:42
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
Only problem is that the update 11 doesn't have any specific requirements. It gives an example of a safe setup. It does not state any need for this particular setup. I personally won't feel that this is adequately covered until they specify max blade size, max rpm, and mandatory specific protective equipment. Any less and it will be too ambiguous.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
  #133   Spotlight this post!
Unread 10-02-2009, 21:24
They "expect that propellers...will be protected in a comparable way." That's not exactly just an example...
I'm not sure that they want to specify those items. They've already spec'd the bumpers to death, so it's either "Do we REALLY want to go farther?" or "Why stop there?". Judging by team reactions to the bumpers, I'd guess the former. I could be wrong.
If they do specify one thing, I would say they should do specific minimum protective equipment, possibly with relation to the size of the prop and the speed.
  #134   Spotlight this post!
Unread 10-02-2009, 21:31
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
First off, Max blade size has little to do with the safety of a prop. A 32" prop can be made safe while a 10" prop could be very unsafe.
Max RPM is a function of prop size and construction. some props are perfectly happy at 20,000 RPM whil others are dangerous at 5,000 RPM. To set an arbitrary 'MAX RPM' may actually encourage poor design and unsafe robots.
As far as mandatory specific protective equipment goes, what may hold a 32" 5,000 RPM prop may not hold a 11" 20,000 RPM prop. Instead of blanket protective equipment (which may or may not work in all cases), require the teams to prove that the setup is safe with proper engineering numbers. Show that the cage will completely contain a catastrophic failure of the prop.
___________________
- Tennyson, Ulysses
  #135   Spotlight this post!
Unread 10-02-2009, 21:44
Molten's Avatar
AKA: Jason
When it says comparable. It says that it is in respect to the danger of the blades. In reality, it really isn't saying much.
Also, I know it is the blade size that makes it dangerous. I also know it isn't the rpm that makes it dangerous. Lets compare to electricity. The current alone won't kill you and voltage alone won't kill you. It has to be together. However, there are standards for both. If nothing else, they could set up a simple formula that would allow for various rpm/diameter possibilities while still restricting the real danger.
Fans/Propellers - Are you doing them? Greg Peshek General Forum 15 06-02-2009 19:50
To those who are officers/admins here... synth3tk General Forum 3 26-09-2008 07:06
For those who lack dedication... Pi Is Exactly 3 Regional Competitions 19 09-02-2005 21:26
Some good humour for those who are bored. Frank(Aflak) Chit-Chat 0 09-12-2003 19:11
For those who were wondering... Nate Smith Championship Event 2 22-04-2002 17:25
