Go to Post *When putting grease on anything* "The bigger the glob the better the job." - TheMagicPenguin [more]
Unread 08-02-2009, 15:45
windell747 windell747 is offline
FRC #2477
windell747 will become famous soon enoughwindell747 will become famous soon enough
Running camera code wirelessly
Hi, We have only tested the camera code on tether and we were suprised that when we ran the code out of the box as a stand alone application, the gimbal no longer tracks the goal. When tethered, the code runs fine, but wirelessly the code doesn't work. We made no modifications to the code to run it wirelessly just to keep troubleshooting simple.
Is there modifications that need to be done to the code to make it work wirelessly?
Thanks!
Unread 08-02-2009, 20:46
Re: Running camera code wirelessly
That is surprising. Do any of your other actuators (motors, relays, servos) work wirelessly? What does the Driver Station show for the battery voltage? What is the state of the Robot Status Light? It might be that the robot isn't getting communication and is disabling its outputs.
Unread 08-02-2009, 21:56
FRC #2477
Yes, we have been developing our own code for the motors and actuators for the past few weeks and we have tested the code wirelessly. I'm baffled by this.
Unread 09-02-2009, 09:04
If you aren't going to answer my questions, I can't help you.
Note that I asked, "Do any of your other actuators work wirelessly?" Not did. Right now, while your camera servos are failing to move using a wireless connection, do motors work?
Unread 09-02-2009, 21:27
FRC #2477
I don't think I tested to see if the motors are working with the camera code. I'll run that test and see what comes up.
Cannot Connect to Axis Camera Wirelessly computerish Technical Discussion 4 11-01-2009 19:19
Problem deploying/running default code blaxbb FRC Control System 0 10-01-2009 11:59
Running K. Watson's code on Edubot, BRLOD Mike Programming 5 25-01-2006 20:30
Strange products upon running code... neilsonster Programming 17 10-08-2005 00:20
Problem running compiled code jskene Programming 10 23-01-2005 21:13
