Go to Post Calculate everything. You won't need to make speed holes if you figure it all out beforehand and get it taken care of. - Otaku [more]
Unread 09-02-2009, 09:19
VEI Dude's Avatar
VEI Dude VEI Dude is offline
Mentor 4024, 4013
AKA: Neil the Real Deal
FRC #4013 (Jokers & Clockwork Mania)
VEI Dude has a spectacular aura aboutVEI Dude has a spectacular aura about
Re: cuting plexi
Other than the table saw type stuff, we use a dremel with a spiral cutting bit (actually a Roto-Zip bit), with a straight-edge clamped to the material as a guide. Works very well.
BTW, don't inhale the fumes! Ventilate!
Cheers,
-Neil.
Unread 15-02-2009, 22:48
CPUgirl CPUgirl is offline
The Girl
AKA: Amanda
FRC #0964 (Bearcats)
CPUgirl is an unknown quantity at this point
Send a message via AIM to CPUgirl
Red face Re: cuting plexi
We always use polycarbonate and always use our bansaw when cutting it. Anything else is much more of a pain the only thing are the little shreds that you have to deal with but if you make sure to keep your mouth closed and of course your safety glasses on (probably semi-long sleeves too) and you should be fine. You grow used to it. Good luck.
pic: Team 2614's Cracked Plexi SlaminSwimster Extra Discussion 19 18-07-2008 00:10
plexi glass clatek Technical Discussion 13 29-01-2006 13:01
Will plexi-glass work? MathewSmith Technical Discussion 33 08-04-2004 07:17
Plexi-Glass walls Brett W Rules/Strategy 8 21-02-2003 22:44
