Go to Post However, mentoring isn't for you. It's for the others. - Alan Anderson [more]
Unread 02-02-2009, 10:15
Kakashi1261's Avatar
Kakashi1261 Kakashi1261 is offline
Driver/Graphic Artist/MechTeam
AKA: Daniel
FRC #1261 (RoboLions)
Team Role: Driver
Kakashi1261 is an unknown quantity at this point
Re: USB Gamepads as controllers?
Originally Posted by Alan Anderson View Post
Plug it in to an xbox 360?
Seriously, that controller does not follow the USB HID standard, and is not usable by the 2009 FRC Driver Station.
we have used an xbox 360 controller for the past 2 years.
2007 we used xbox 360 controller, and a guitar hero controller.
2008 we used an xbox 360 controller and a basic button system for the other.
. . : : T E A M : : . .
«_____________________»
«__1___2_2_____6___1__»
«__1__2___2___6____1__ »
«__1_____2___6_____1__»
«__1____2___6__6___1__»
«__1___2____6___6__1__»
«__1__2222___6_6___1__»
∙ ∙ : : D R I V E R : : ∙ ∙
Unread 02-02-2009, 10:42
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
What Alan is saying is that the Xbox 360 controller is not compatible with the new driver station. If you plug it in you will find that it doesn't work.
Unread 02-02-2009, 13:15
The Chicklet USB-to-gameport translator has programming that allows it to talk the Xbox 360 controller's language. There are drivers for Windows to do the same thing.
The 2009 FRC Driver Station lacks the necessary driver.
You can use an Xbox 360 controller plugged in to an appropriately-configured Chicklet connected to the analog and digital headers on the side of the Driver Station, and probably get it to work the same way it did last year. I think that's a lot of extra work and wiring, and I think you'd be better off with a standards-compliant HID game controller.
Unread 02-02-2009, 16:19
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
If anyone can post a tut or a vid of how to do this, our team would appreciate it.
R.C.
MadTown Robotics Team 1323
Unread 02-02-2009, 18:17
You'd also have to rig up a boost power supply for the chicklet, as the DS only supplies 5V, but the chicklet wants 7.2-12v and using a battery on the operator console isn't legal this year like it was in the past. I guess you could probably also bypass the regulator on the chicklet. Neither would be trivial to do safetly
Since the chicklet is no longer available, I wonder if it would be legal to use on the operator console in the first place?
Unread 05-02-2009, 02:17
nathan.chupp's Avatar
nathan.chupp nathan.chupp is offline
AKA: CupCake
FRC #3509 (Fallout)
Team Role: RoboCoach
nathan.chupp is an unknown quantity at this point
It dose not work in a 360's it's for my pc..
Unread 08-02-2009, 04:48
Blackstarr904's Avatar
Blackstarr904 Blackstarr904 is offline
Junior Mentor
FRC #0904 (D3)
Blackstarr904 is an unknown quantity at this point
Could a generic (logitec or something else common) usb gamepad be used in place of the usb joysticks?
Yes they can. We have been using one recently (especially yesterday) and it works AWSOME. It gets some getting used to compared to joystick drive (from what i have seen so far by watching the drive team.. havent been able to test drve this year yet )
Unread 08-02-2009, 23:58
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Any xbox 360 controller that works for the PC should also work for the 360...
Unless you have some weird off-brand controller that looks like a 360 controller but really isn't?
Unread 09-02-2009, 09:20
CH Flightsticks were legal in previous years if they were unmodified from their "off the shelf" condition, despite being unavailable for purchase.
The main rule that keeps Chicklets from being used during competition is <R81>, which prohibits "portable computing devices" on anything but the Ethernet ports, with no exceptions.
Unread 13-02-2009, 22:29
chmp09 chmp09 is offline
AKA: Marc Pulte
FRC #1702 (Robocubs)
chmp09 is a jewel in the roughchmp09 is a jewel in the roughchmp09 is a jewel in the rough
how do i get my xbox 360 control to work????
I don't think you can. It does not use default driver. The basic rule of thumb is if you have to install software to get it to work on a PC, it probably wont work with the DS.
Unread 21-02-2009, 16:14
keehun's Avatar
keehun keehun is offline
Team Captain
AKA: Keehun Nam
FRC #2502 (EP Robotics)
keehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond reputekeehun has a reputation beyond repute
Send a message via AIM to keehun
We use a better logitech that has a twist stick and buttons organized in to only one side so buttons are more accessible
For by grace you have been saved through faith, and that not of yourselves; it is the gift of God, not of works, lest anyone should boast. -- Ephesians 2:8-9
2010: Quarter Finalist (MN 10,000 Lakes)
2010: Website Award (MN 10,000 Lakes)
2009: Quarter Finalist (MN 10,000 Lakes)
2009: GM Industrial Award (MN 10,000 Lakes)
IR controllers Bsteckler General Forum 1 23-02-2008 11:07
away around the USB chicklet for using USB Controllers Stobei Programming 2 26-01-2008 14:27
Wireless Gamepads lazyxninja Control System 1 27-01-2007 15:35
Gameport to Usb cable vrs. Usb Chicklet haywirerobotics Control System 4 25-01-2007 19:03
USB and Mac Support for IFI FRC Controllers??? RIgnazio Rumor Mill 26 23-09-2005 17:31
