Re: 5th gear Simulator help
Hmm, thats really odd. Why is it looking in your windows System32 folder for your files? It sounds like the working directory of shortcut you use to launch it is wrong. If you right click on the shortcut and choose properties you can check that the "Start In" directory points to the 5th Gear root directory.
| 2009 5th Gear FRC Match Simulator | gblake | Technical Discussion | 36 | 10-01-2010 21:16 |
| Lockheed Martin/5th Gear Game Simulator... | ttldomination | General Forum | 1 | 27-01-2009 21:44 |
| Helical gear help | Gui Cavalcanti | Technical Discussion | 1 | 27-01-2003 16:20 |
| Help Gear Ratios !!!!!!! Help | sanddrag | Technical Discussion | 5 | 16-08-2002 15:09 |
| Gear/Sprocket Help | Joseph F | Motors | 3 | 18-03-2002 07:48 |
