#31
Re: 10 Balls. 1 Second. Team 100.
Beast.
#32
take cover, thats scary
#33
Awesome, Awesome, Awesome.
Good job guys! |
#34
![]() Great robot, I hope I get to see it in real life! |
#35
Well actually only 2 ties (if you are referring to the SAC quarter finals in 2007), but at least it won't be pushed to 5 matches.
#36
In any case we don't have to shoot all the balls in the magazine. The intake/elevator is on a victor so we can vary the speed and only feed a few balls in at a time. We are also adept at both ground and HP loading. So we should be able to reload fairly quickly... or pickup what we've already missed. |
#37
I'm really hoping that this machine only works right when tipped 90 degrees....oh well. Wishful thinking.
![]() Awesome Job guys! Keep up the great work! |
#38
This is almost exactly our design.
The only difference is that you guys have separated the balls in to independent columns which is probably more effective. Its always reassuring to share a design with a respected, competitive and veteran team. |
#39
I counted 3 seconds. The thread title is misleading.
Though, that is still amazing. Personally, I think this is an amazing robot and a great feat of engineering. But I still need to see it with a moving target before I can really tell how well it will do at a comp. Good luck to your drivers. They have a great bot to drive, they just have to use plenty of finesse. |
#40
I think it will be difficult to accurately align on a goal from that distance.
Also, how long does it take to load balls into that configuration? Can you only hold 10 balls? Quote:
#41
Nice robot. I've watched this team at Portland before and they are always competitive. Good job. |
#42
It makes a lot of difference if they are repeatedly shooting you. Also, If you can tell their robot is going to shoot in two seconds, you might be able to use this to help dodge. Again, nothing against the design it is awesome. Just that when you are the prey, ever second matters.
#43
.I'd be much more afraid of a robot that lines up, then can immediately shoot 10 in a second. A robot that has to line up, then go 1, 2, shoot 10, doesn't scare me one bit. |
#44
It appears as if there's no reason that, once they've loaded 10 balls into the machine, it can't be cocked and ready to fire.
#45
WOW.
| Please Help!Young Team 195 Member Loses 100 Team Buttons | Ericgehrken | Chit-Chat | 8 | 24-04-2008 21:32 |
| Team 100 Awesomeness | spinmunky | Robot Showcase | 11 | 16-02-2008 11:10 |
| 10 Balls per second? | Travis Covington | Rumor Mill | 103 | 26-07-2006 00:06 |
| Team 100 unveiling | Cory | Robot Showcase | 2 | 26-02-2003 00:51 |
| TEAM 100 Website | archiver | 2001 | 0 | 24-06-2002 02:56 |
