Thread Tools |
Rating:
Display Modes |
Re: Cruch Time Help! 3 LabVIEW Tutorial Videos: State Machines; Faster Code; Simulati
Alan,
Trust me, the video is there. The video call itself is buried in a js script, which unfortunately means you need js enabled to view it. Ben |
Oh, I trust you. Other people don't seem to be having any trouble with it.
The "video call" must be very well hidden. The only javascript I see on the page is a trio of scripts in the <head> that actually look like they're skipped for non-IE browsers, and something that looks like line noise after the "click here to install the latest version of flash" link. Based on that, I tried viewing it with Internet Explorer (on a Windows computer, even). There still is nothing obvious to click in order to view the video. Where is it supposed to be on the page? There is a largish blank spot after the "latest version of flash" and before the "Testimonials / Want to See More? / Already Registered?" where that cryptic script would fit, but it doesn't respond to clicks and doesn't show any hidden text when I select through it. Oh, and one other weird thing about the Tip Jar pages: no matter how wide I make the window, the bottom scroll bar never goes away. |
It looks like the line that inserts the inline Flash player is this: (it comes on the line in the source right after "Trouble viewing these videos?")
<SCRIPT language='JavaScript' type='text/javascript'>var code="'1AQAPKRV'02nclewceg'1F'05HctcQapkrv'05'02v{rg'1F'05vgzv-hctcqapkrv'05'1Gtcp'02WPN'1Fuklfmu,nmacvkml,jpgd'1@tcp'02qrnkv'02'1F'02WPN,klfgzMd'02'0:'02'00ntocqvgp{,amo'00'0;'1@kd'02'0:qrnkv'1A2'0;'02'5@nmacvkml,jpgd'1F'00uuu,ntocqvgp{,amo'00'1@'5Fgnqg'5@fmawoglv,upkvg'0:wlgqacrg'0:'00'071Akdpcog'0702qpa'071F'0700jvvr'071C--uuu,ntocqvgp{,amo-dkngq-VkrHcp37]:Dg`2;-VkrHcp37]:Dg`2;,jvon'0700'0702ukfvj'071F'0700:42'0700'0702jgkejv'071F'0700442'0700'0702ocpeklukfvj'071F'07003'0700'0702ocpekljgkejv'071F'07003'0700'0702dpcog`mpfgp'071F'07002'0700'0702kf'071F'0700gzvgplcn'0700'071G'071A-kdpcog'071G'00'0;'0;'1@'5F'1A-QAPKRV'1G"; var res="";var len=code.length; var i;for (i=0;i<len;i++) {res+=String.fromCharCode(code.charCodeAt(i)^2)} res=unescape(res);document.write(res);</SCRIPT><table>
{removed by request} Last edited by Dave Flowerday : 09-02-2009 at 14:10. |
Guys, I appreciate the interest!
The line you are referring to is an obfuscation, which is intended to make it difficult for sites to extract my videos and play them without my knowledge or approval. Personally, I don't think that's unreasonable?!? Even if that wasn't there, the tool I'm using to create these screencasts is Camtasia Studio, and it uses a javascript controller to play the flash video files. Now, I'm never one to complain about any attention, good or bad, and I'm sorry if the way I posted my videos is distracting, but I'm not really sure its relevant to this forum. I'm a LabVIEW programmer, not a web programmer, and the web development tools I'm using seem to work well for for most situations, but if you are having trouble, I'd be happy to help as much as I can. However, I won't be able to remove the js requirement, and, frankly, you are the first ever to comment on it being an issue. Ben |
#7
I haven't tried accessing the lvmastery site using my home connection since I got the information that JavaScript is strictly required. I'll try to remember to give it a go again late this evening when I'm there (it's a real pain not having Internet access at the robotics shop). |
| Good online tutorial explaining the Gravity simulation in Solidworks? | Elgin Clock | SolidWorks | 7 | 24-06-2009 22:05 |
| LabVIEW Video Tutorial - Debugging Your FRC Code | LVMastery | NI LabVIEW | 0 | 26-01-2009 09:28 |
| help me in LabView code | mahmosh | National Instruments LabVIEW and Data Acquisition | 3 | 11-01-2009 00:18 |
| State Based Machines in LabView | Greg Marra | General Forum | 0 | 11-11-2008 11:07 |
| State Machines | doyler | Programming | 7 | 11-01-2005 00:53 |
