Go to Post If people are getting offended at seeing other teams list their accomplishments, maybe they should spend less time whining and more time doing things to make their own team win. - artdutra04 [more]
Unread 09-02-2009, 12:08
Re: Tunnels in loops
Originally Posted by krupinski View Post
I am not a programer by any complicated means, so when my actual programers bailed on me over the last week and we still had no code, i took it over. I worked with a minimal amount of ladder logic before, and i mean like lego mindstorms minimal, but i was able to build a vi for a RT target, not the FRC framework and got it running, now im trying to put the code i had into the FRC project and im having issues with tunnels into the loops not being connected in the other states, such as the case structures for teleop, do i need to terminate everyting inside? or is there something im missing??
A case structure that has output tunnels needs each case to push information to those tunnels. Otherwise you could run into a situation where a wire doesn't have any data.
A tunnel that is missing cases looks hollow - flip through the cases to find the missing pieces.
PID vs Normal loops 3DWolf Programming 20 14-12-2007 13:41
Crazy Loops whytheheckme Programming 16 05-02-2007 00:51
While loops Guy_E VEX 6 01-11-2006 22:04
loops inside of subs??? manodrum Programming 4 19-02-2003 20:05
Programming Loops Mike o. Programming 5 26-03-2002 11:24
