Go to Post If you need persuasion woven tight with logic, leave it to a software architect. - Richard Wallace [more]
Unread 09-02-2009, 10:48
programmr's Avatar
programmr programmr is offline
AKA: Face
FRC #0522
programmr is a jewel in the roughprogrammr is a jewel in the roughprogrammr is a jewel in the rough
Send a message via AIM to programmr
Question joystick and relay programming plz help!
i have
Joystick* thirdStick; //Joystick USB3
Relay* agitator; //Relay 1
Relay* agitator2; //Relay 1
thirdStick= new Joystick(3);
agitator = new Relay(1, agitator->kBothDirections);
agitator2 = new Relay(1, agitator2->kBothDirections);
if (thirdStick->GetRawButton(1)) {
agitator->Set(agitator2->kReverse);
else {
agitator->Set(agitator2->kOff);
i want to know how can i make the relay go forward and then go reverse based on either the x or y axis of the joystick: example:
x axis : left makes relay1 go rev, right makes relay1 go fwd
Please help! thank you!
"I would love to change the world but no one will give me the source code"
Unread 09-02-2009, 12:08
pheadxdll pheadxdll is offline
AKA: Alex
FRC #1225 (Amperage Robotics)
pheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud ofpheadxdll has much to be proud of
Re: joystick and relay programming plz help!
You can use the GetX method from the Joystick class to return a float of the joystick from -1.0 to 1.0:
If you lean over half way to the left (on the x axis) it turns the relay reverse. The opposite then for the right direction and then off for in the middle.
if(thirdStick->GetX() < -0.5) // IF OVER HALF WAY LEANING TO THE LEFT
     agitator->Set(Relay::kReverse);
else if(thirdStick->GetX() > 0.5) // OVER HALF WAY TO THE RIGHT
     agitator->Set(Relay::kForward);
else // NEITHER/IN BETWEEN
     agitator->Set(Relay::kOff);
Amperage Robotics Team 1225
Site under-going revamp. :/
Unread 09-02-2009, 13:22
programmr's Avatar
AKA: Face
FRC #0522
thank you very much!
How do I program a relay to turn on and off by pressing a button on the joystick? eweathers NI LabVIEW 4 28-01-2009 22:34
Joystick Button Programming in Labview Help Needed domoarigato NI LabVIEW 11 28-01-2009 10:55
Programming Joystick Buttons to toggle a motor on and off programmr C/C++ 6 25-01-2009 17:47
Programming Help- 2 Motor 2 joystick Drive System OMAR_567 Programming 2 02-02-2008 14:08
i need specs for motors and pumps in the kit from last years competition plz help SCYTE16 Motors 3 18-11-2004 22:54
