Go to Post If you have the time to be caught up on Delphi and the Q&A forum, then you have time to go write a WFA entry. No more excuses. Go! Write! Now! :) - Jessica Boucher [more]
Unread 08-02-2009, 21:00
marccenter's Avatar
marccenter marccenter is offline
FRC #3548 (RoboRavens2)
marccenter has a spectacular aura aboutmarccenter has a spectacular aura about
Smile Location of WPI Library cpp files attached to Windriver
Hey folks,
I did a windows search for some of the WPI library files and did not find them on my local hard drive. Where are the WPI library files hidden relative to WIndriver? I see the *.h files but not the *.cpp files.
Marc Center
FIRST FRC Mentor/Coach - Team 3548 Royal Oak RoboRavens#2 - on Sabbatical 2017 season
marc.center@gmail.com
Mobile: 248-255-7377
Unread 08-02-2009, 23:42
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Location of WPI Library cpp files attached to Windriver
They do not come with it, they are pre-compiled. You can download the WPILib files off of the WPI site if you would like though.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 09-02-2009, 07:57
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Originally Posted by marccenter View Post
Hey folks,
The source code is not included with the default installation package. However, they can be downloaded separately from the same place that the updated installation packages can be found:
http://first.wpi.edu/FRC/frcupdates.html
The direct link to the Update 3.0 source code is http://first.wpi.edu/Images/CMS/Firs...SourceCode.zip
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 09-02-2009, 12:20
marccenter's Avatar
Question Re: Location of WPI Library cpp files attached to Windriver
Hey guy's thanks for info.
Part 2 now: I wanted to create my own version of TankDrive so I could have a rate-limited (RL) input for acceleration control (TankDriveRL) by comparing last loop value to present loop value. I began modifying TankDrive by copying/pasting to TankDriveRL within Robotdrive.h but couldn't really finish because I did have access to Robotdrive.cpp source code. What do you recommend to proceed? (I am new to C++ and Windriver development environments)
1) Figure out a way to modfy Robotdrive.cpp? (seems not possible)
2) Create new files(*.h, *.cpp) for TankDriveRL and make up new TankDriveRL class/method?. (most likely candidate).
Marc Center
Unread 09-02-2009, 14:21
I wanted to create my own version of TankDrive... I began modifying TankDrive by copying/pasting to TankDriveRL...
Don't copy and paste. Inherit. Make a new class based on the old one, and replace the relevant methods to incorporate your rate limiting.
I'm not the right person to give detailed directions on exactly how to do that. Someone else with more C++ expertise than I do will have to help you further.
Unread 11-02-2009, 12:47
j_johnson j_johnson is offline
FRC #0226 (Hammerheads)
j_johnson is an unknown quantity at this point
Another good option for operations like this is to use a pipeline pattern. Our team created a class that inherits from SpeedController and takes another SpeedController as it's output. Inside this class's Set method, it procceses the input and passes the result to the output. This pattern allows you to create classes to perform operations such as rate limiting, traction control, velocity control, etc. to each act individually. You can then chain them together through the constructors as below.
float accelLimit = .03;
SpeedController leftDriveMotor = new Jaguar(1);
SpeedController leftAccelLimiter = new AccelerationLimiter (leftDriveMotor, accelLimit);
SpeedController leftTractionControl = new TractionControl(leftAccelLimiter);
SpeedController rightDriveMotor = new Jaguar(2);
SpeedController rightAccelLimiter = new AccelerationLimiter (rightDriveMotor, accelLimit);
SpeedController rightTractionControl = new TractionControl(rightAccelLimiter);
m_robotDrive = new RobotDrive(leftTractionControl, rightTractionControl);
This makes it very easy to test each piece individually and then chain them together.
Possible confusion between competition location and shipping location rl1806 General Forum 2 07-02-2009 00:27
Need Help Locating .h and .cpp files jkjohnson Programming 0 30-01-2009 09:00
downloading the WPI library off the SVN nickmagus Programming 13 05-01-2009 14:29
cRIO-FRC Training Video: WPI Library Overview BLAQmx National Instruments LabVIEW and Data Acquisition 5 09-11-2008 19:58
Where is WPI Library Information PDF? koenig3456 Programming 2 15-01-2006 16:19
