Go to Post People will only work toward common goals when they are part of the goal-setting process. - GaryVoshol [more]
Unread 09-02-2009, 14:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Ultrasonic Sensors
Originally Posted by nathanww View Post
I'm not a labview programmer, but as I understand the built-in ultrasonics routines are for digital ultrasonic sensors(the system sends out a ping and then waits to hear the returning ping). The maxbotics has a coprocessor that does this, so instead of using digital pulses, it just sends you back an analog value, which you can read the same way you'd read a potentiometer.
The maxbotics will send PWM values or analog values. Take your pick.
If you use the analog values, you can simply read the analog channel and divide by a constant to get number of inches.
No idea about the ultrasonics sensor VI - it was easier for me to do it the way I stated since we used them last year.
WPILib and Ultrasonic sensors DanielR. Programming 7 18-06-2008 17:31
Parallax and Maxbotix ultrasonic sensors Lucretius Programming 5 20-02-2008 14:34
Ultrasonic sensors on digital ports 3-6 problems wt200999 Programming 14 13-02-2008 08:13
Ultrasonic range sensors for Vex Robot OneCoolDude Programming 1 01-12-2007 09:22
can we use ultrasonic sensors? GMKlenklen Electrical 20 15-01-2007 14:34
