Go to Post Right, play to win. Play to win the event or play to win one match? This year, unfortunately, they are not the same thing. - Paul Copioli [more]
Unread 05-02-2009, 15:48
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
DS Power Source
While operating tethered, for instance at one of the "practice fields" they set up at a competition venue, what is the power source for the DS?
Perhaps I'm missing something - I rescanned the controls documents and didn't see anything, however.
Is 110AC required for the DS, or can it obtain it's power from the robot, through the ethernet tether cable? I suspect the answer is yes you need 110 AC, but I wanted to find confirmation and have been unable to.
This could be problematic if a team needs to run out to the field after an aborted auton round, etc to reset their robot - they likely won't have 110 AC power to hook their DS up to on the field.
Unread 05-02-2009, 16:28
EHaskins EHaskins is offline
AKA: Eric Haskins
no team (CARD #6 (SCOE))
Re: DS Power Source
The DS needs external power. You can improvise 12v power sources other than the 110v adapter.
Eric Haskins KC9JVH
Unread 05-02-2009, 21:33
Electrical Engineer
Rookie Year: 1995
Re: DS Power Source
Tom,
To the best of my knowledge, FIRST is looking at this issue. I would hope that we see something in an update soon...
Mike
Mike Betts
As easy as 355/113...
Unread 06-02-2009, 10:43
Re: DS Power Source
I've been running ours off a 9.6v Vex battery with an adaptor to the barrel connector used by the DS.
You can do the same with AA batteries in a 12v cluster.
If you ever built a battery supply for the old IFI Operator Interface that works with the new DS too.
Although it seems to work at least down to 9v, I'd probably upgrade it to use 12v.
Unread 09-02-2009, 14:37
Tom Line's Avatar
Re: DS Power Source
Well isn't that interesting.
I think I'm going to find a use for our old back-up batteries, since we don't need them anymore.
Woot!
FIRST:Source Birdman1011395 IT / Communications 7 22-02-2006 07:17
Green Light Power Source BobC Kit & Additional Hardware 19 20-01-2006 14:44
IC clock source John Gutmann Electrical 4 14-07-2005 23:19
Four Wheel, all steering, non-omniwheel, ONE power/motor source drive FizMan Technical Discussion 31 27-04-2004 12:12
Differences in Source? Adrian Wong CD Forum Support 1 27-05-2002 20:23
