Go to Post I was not looking at this as a backdoor to asking Brandon to do it (when I have impossible/unreasonable tasks I want done, I ask him straight out ;-) - Joe Johnson [more]
Unread 09-02-2009, 17:01
Alphabet OJ's Avatar
Alphabet OJ Alphabet OJ is offline
I do what they say me to.
AKA: Jacob G.
FRC #2169 (KING TeC)
Team Role: Student
Alphabet OJ is an unknown quantity at this point
Encoder for Crab Steering
Hello!
We have built a crab-drive robot for this year (2009) and we need a sensor to find where the wheels are facing to use in the program.
We are pretty sure we are going to use a 270 degree potentiometer, but we want to look at an encoder because it will be easier to mount.
We would use the kit-of-parts encoder, so it is not absolute like a potentiometer would be. The program would need to remember that "we are 10 ticks to the right of center" and stuff like that, and we would need to start the robot with the wheels strait forward every competition. We also are worried that it would "forget" its position after autonomous. For example, if we steered 10 clicks past center to the right in autonomous and then we changed to teleoperated, could the code remember where the wheels were? Or is the memory cleared at the end of autonomous?
Any help would be great! If anyone has used encoders for crab steering before or something like that, we'd love to hear from you. Thanks!
Alphabet Orange Juice
ABC OJ
ABCOJ
JACOB
Jacob
Unread 09-02-2009, 17:05
popo308's Avatar
popo308 popo308 is offline
AKA: Brent
FRC #1625 (Winnovation)
popo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to allpopo308 is a name known to all
Send a message via AIM to popo308
Re: Encoder for Crab Steering
On our crab drive we use the MA3 absolute analog encoder-> http://usdigital.com/products/encode...ary/shaft/ma3/
used it for two years and have had no failures!
they are solid and robust also they have a nice resolution!
also not to expensive
Unread 09-02-2009, 17:10
If you don't want to reset the crab modules to 0* each match, you would need to add an index to the encoder (limit switch, reflective tape, etc) to know your absolute angle. Or you could check out one of these US Digital Absolute Kit Encoders. These mount the same way as the KOP encoder, but let you read absolute rotation (0-360*) on an analog input pin.
To remember variables across methods in your code, just declare the object globally in the class.
class YourRobot : public SimpleRobot{
    Encoder *crab;
    YourRobot(void){
        crab = new Encoder(1,2);
Unread 09-02-2009, 17:13
M.Rehberg's Avatar
M.Rehberg M.Rehberg is offline
AKA: Mike Rehberg
FRC #2619 (The Charge)
M.Rehberg is an unknown quantity at this point
Our team went though the same set of questions (pot Vs encoder), and ended up with the standard encoder, and two limit switches. The limit switches are at the end of travel, one for each direction of turn. The software can calibrate itself by turning the wheels to either limit switch, and then going back 155 counts (for our bot it is 310 from stop to stop). So far it works great.
Unread 09-02-2009, 20:49
Nate Edwards Nate Edwards is offline
SWARM Head Mentor
FRC #0957 (SWARM)
Nate Edwards will become famous soon enough
We are using a cheap absoulte encoder, it worked on the bench, tonight it should work on the robot. Here is the link to it and some places to buy it, we bought ours from allied but they are sold out I beileve.
http://octopart.com/info/Bourns/EAW0J-B24-AE0128L
South West Albany Robot Mechanics
2002 Pacific NW Regional Rookie All Star Award Winners
2003 Pacific NW Regional Daimler Chrysler Team Spirit Award Winners
2004 Pacific NW Regional Johnson & Johnson Sportsmanship Award Winners
2004 Pacific NW Regional Winning Alliance (492 (#1 Seed), 1031, 957)
2003 & 2005 Pacific NW Regional Chairman's Award Winners
2009 Oregon Regional Woodie Flowers Award Winner
Crab Steering on Regolith Dan2081 General Forum 33 09-01-2009 16:35
Steering for mecanum? eyekantspel Control System 9 09-01-2008 21:58
need glp programing steering with a steering wheel Matchew Programming 2 10-02-2003 14:20
What is crab steering?? Adam Y. Technical Discussion 18 30-12-2002 08:12
4 wheel steering/ Crab Huey_Da_X-cat Technical Discussion 3 11-02-2002 22:49
