Go to Post Ahem......"where are the President's safety glasses???" - Travis Hoffman [more]
Unread 09-02-2009, 17:04
nofar#1943 nofar#1943 is offline
FRC #1943
nofar#1943 is an unknown quantity at this point
Problems with the RSL
Hi
Our team was trying to connect the Signal light for 3 days with no success.
We searched on the web and found no answers.
we connected the signal light with 3 wires:
A wire connecting La and Lb
Lb---|
La---|
A wire connecting N and the negative on the sidecar
N-----------(RSL negative on the sidecar)
A wire connecting La and the positive on the sidecar
La----------(RSL positive on the sidecar)
Our signal light is not responding when we turn on our robot, neither the LEDs next to the RSL conncetion on the sidecar.
We will appreciate the help.
Team #1943
Unread 09-02-2009, 17:10
Electrical Engineer
Rookie Year: 1995
Re: Problems with the RSL
Connect the RSL exactly as shown on the Power Distribution Diagram and it should work fine.
Regards,
Mike
Mike Betts
As easy as 355/113...
Unread 09-02-2009, 17:35
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Your description of your connections sounds consistent with the Power Distribution Diagram.
Here are a few things to check on:
1. Is the Digital Sidecar properly connected to the Power Distribution Board? Make sure the Power, 5V, and 6V LEDs light up when power is applied. Make sure that the Wago terminals on the Power Distribution Board and the Digital Sidecar are grabbing the wire and not the insulation, If the wire is not stripped long enough the terminals can grab the insulation.
2. Is the Digital Sidecar connected to the cRIO with the 37 pin cable?
2. Did you try the other Digital Sidecar to verify it is not a hardware problem with the one you are using?
Unread 09-02-2009, 17:49
It's not your wiring of the RSL that's a problem. The RSL just repeats what the LED beside the RSL connector is doing, and if it's never on, then the RSL shouldn't be on either.
Something to add to the checklist.
-Is your module that the Digital Sidecar is connected to in slot 4 (slot 6 doesn't use the RSL)?
-Have you re-imaged your cRIO with the latest v11 contained in Update 3a (the OTB version doesn't use the RSL)?
-Check your other indicators for clues, such as the Driver Station Battery status.
I'm pretty sure Vikesrock meant the white Wago connector that brings 12v power to the Digital Sidecar in #2 above, not the RSL connector which is a standard 2-pin .1" header.
Unread 09-02-2009, 17:59
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Thanks Mark, I must have gotten a bit mixed up when I was writing that post. I went back and edited it so it should be correct now.
Unread 09-02-2009, 18:03
FRC #1943
To Vikesrock:
-The digital sidecar is connected properly and everything except the RSL works perfectly.
-The RSL terminals are grabbing the wire and not the insulation
-We have tried the other sidecar
To Mark McLeod:
-Our module is connected to slot 6, does it matter?
-Our cRIO is updated
-The white wago is connected properly
Unread 09-02-2009, 18:16
Disconnect the RSL and see if the LED next to its connector lights. You might have a short somewhere.
Try enabling a relay - they are on the same chain as the RSL, and they have indicator LEDs.
Unread 09-02-2009, 18:30
Originally Posted by nofar#1943 View Post
To Mark McLeod:
Bingo.
Slot 6 does not use the RSL, so it will be off all the time.
Your module must be in slot 4 to play.
And you can call me Mark, we're colleagues
Unread 10-02-2009, 08:29
FRC #1943
Thanks Mark!
It works now, i can't belive how simple the problem was.
Unread 12-02-2009, 12:02
bixbyrobotics1 bixbyrobotics1 is offline
Whiteway
AKA: Alex Whiteway
FRC #2424
bixbyrobotics1 is an unknown quantity at this point
Send a message via AIM to bixbyrobotics1
Our signal light does not work either. I have a voltage reading on the terminals of the light, but no blinky-flashy
Any ideas?
Unread 12-02-2009, 12:11
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Have you checked your wiring per the Power Distribution Diagram? (link in one of the above posts)
If you've got voltage on the RSL output, there's no reason for no light other than bad wiring or broken light. You could also plug it into a 20A breaker to confirm the wiring.
Russ
Unread 12-02-2009, 15:28
Whiteway
AKA: Alex Whiteway
FRC #2424
I will try these ideas and see what happens. What do we do if we have a bad light?
Unread 13-02-2009, 21:48
Wendy Holladay's Avatar
Wendy Holladay Wendy Holladay is offline
FRC #1912 (Team Combustion)
Wendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond reputeWendy Holladay has a reputation beyond repute
dumb question, but what type of connector do we use on the digital side car for the rsl light, what is
standard 2-pin .1" header??
did it come in the kop??
doesn't look like a wago style on the side car
thanks in advance
Unread 13-02-2009, 22:09
In this photo of the Control System parts: http://www.chiefdelphi.com/media/img...d504b545_l.jpg
They are the coiled grey cables all the way to the bottom right.
They have 2-pinconnectors at either end. Cutting them in half gets us two connections.
No RSL on Digital Sidecar shobuda999 FRC Control System 16 08-02-2009 14:28
Problems with the connections to the Keyang motor nofar#1943 General Forum 2 01-02-2009 19:27
Problems with the manual of the green target (for cmu cam) Kawashima Kit & Additional Hardware 1 28-01-2007 13:31
problems mounting the camera to the 'bot with the default servo/mount set up Redneck Programming 0 16-02-2005 20:53
Problems with the stretcher? archiver 2001 3 23-06-2002 23:20
