Go to Post we need a diverse team, and until we can welcome someone that's not a nerd, I don't think we're really successful in our recruiting. - JBotAlan [more]
Unread 09-02-2009, 15:39
zackcool123's Avatar
zackcool123 zackcool123 is offline
FRC #1886
zackcool123 can only hope to improve
Exclamation Camera Distance Calcualtor for Labview
Does anyone have or know of a program in labview that uses the camera to track distance?????
Unread 09-02-2009, 17:14
daltore's Avatar
daltore daltore is offline
Electronics/programming/design
AKA: Aaron Osmer
FRC #3529 (ausTIN CANs)
daltore has a spectacular aura aboutdaltore has a spectacular aura aboutdaltore has a spectacular aura about
Send a message via AIM to daltore Send a message via MSN to daltore Send a message via Yahoo to daltore
Re: Camera Distance Calcualtor for Labview
No, but if you know the height and angle of the camera from the ground, you can figure out the number of pixels between the target and the ground and use that as a scale (because you know the height of the target) to find the distance.
Unread 09-02-2009, 17:18
Cjmovie's Avatar
Cjmovie Cjmovie is offline
1293 Resident Hacker
AKA: Christopher Corsi
FRC #1293 (D5 Robotics)
Cjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to allCjmovie is a name known to all
What you are going to want to do is find a modeling equation and then use that. The apparent size of the target and the distance have a relationship approximated by D=sqrt(k/A), where k is a constant and A is the apparent area of the target (in this case, in pixels). You will need to take a few data points of distance and area to find a good K value. It should be approximately constant throughout all data points. If it isn't, the tracking color ranges are probably not catching all of the target in the current conditions, or the target is not pointed directly at the camera. This formula works best when the camera is near-level with the target.
Other possibilities include finding the angle the camera is pointing, and knowing the height of the target, use trigonometry to find an approximate distance.
D5 Robotics, Team 1293: Programmer, CAD'er, Mechanical, Electrical... I've made my rounds.
Events: 2006-2009 Palmetto Regional
Website: http://d5robotics.org/
Unread 09-02-2009, 17:25
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Please take a little time to search before you post. Searching for camera distance yields this thread as the 6th result:
how to find distance using two color servo camera?
Thanks and good luck,
--Ryan
FRC 766, 2015-, Mentor
Encoders and distance (labview) MorbidAngel NI LabVIEW 3 23-11-2008 12:18
Calculating Camera Distance Inoperational Programming 6 04-02-2007 23:48
Labview Demo File for 2006 Camera? JABianchi General Forum 2 15-09-2006 18:23
Camera Tracking Maximum Distance MikeDubreuil Programming 0 18-01-2006 10:18
