Go to Post The future is being developed by FIRSTers! - Andy Baker [more]
Unread 06-02-2009, 22:48
PWHSrobotics PWHSrobotics is offline
PWHSrobotics is an unknown quantity at this point
AI Programming
This is a noob question,
How do I send other references (like sensors) to the AI VI ? it doesn't use the front panel like I normally send VI's references.
Unread 06-02-2009, 22:56
airnate airnate is offline
FRC #0236 (Techno Ticks)
airnate is a jewel in the roughairnate is a jewel in the roughairnate is a jewel in the rough
Re: AI Programming
Sorry. Maybe I'm missing something obvious, but what are you referring to as the AI vi?
Unread 06-02-2009, 23:16
Re: AI Programming
sorry, my bad
'Autonomous Independent' VI in labview I want to send it other sensor references, also how do I send it just the normal 'Motor' Control from the Arcade drive provided in the default Robot Basic VI
Unread 06-02-2009, 23:44
Re: AI Programming
Probably the easiest way to do this is to create more controls on the Basic Robot Global.vi, which as the name implies, is a global variable.
For instance if you want to pass an Accelerometer device reference to the Autonomous Independent vi,
1. Drop the Accelerometer Open.vi in Basic Robot Main.vi
2. Double click the Accelerometer Open.vi to open it.
3. Copy the AccelerometerDevRef (select the indicator and press Ctrl-C)
4. Open Robot Global.vi from the project window.
5. Paste the AccelerometerDevRef on the Robot Global.vi and name it (let's say "Accel1" for this example).
6. Drag the Robot Global.vi from the Project window to the Basic Robot Main.
7. Click on the Robot Global and select "Accel1" (or whatever you named in step 2).
8. Wire the Accelerometer Open.vi to the Accel1 global
9. Drag another Robot Global.vi from the project to Autonomous Independent vi
10. Right click on it and select "Change to Read"
11. use it to wire whatever you're going to do with the sensor.
You can see that the basic robot framework already has a RobotDriveDevRef which may be the "motor" reference that you were asking about.
Actually, you should be careful to distinguish between "drive" references and "motor" references. The "Drive" VIs are used where two or more motors used together as a drive system (e.g. arcade, tank). The "Motor" VIs are used for control of a single motor.
Unread 08-02-2009, 21:16
Re: AI Programming
thankyou guys for your help. Got another question (of course lol) the new Get Alliance VI ...I get red/blue alliance, but it gives you position 1-3, what position corresponds to where on the field.
Much appreciated for your help.
Unread 08-02-2009, 23:17
Re: AI Programming
I think that will indicate which initial location on the field a robot will start in.
Greg McKaskle
Unread 09-02-2009, 07:37
Re: AI Programming
yep, I know Was just curios as to what number corresponded to which spot. for I can incorporate that into the Auto period.
Unread 09-02-2009, 08:14
PhilBot's Avatar
PhilBot PhilBot is offline
Get a life? This IS my life!
AKA: Phil Malone
Re: AI Programming
no, the position related to where your drivers are. Not a lot of use for auto.
Phil Malone
http://www.GEARSinc.org
Unread 09-02-2009, 18:54
Re: AI Programming
yes, but just for kicks, how does the numbering work? Does anyone know? is 1 closes and 3 farthest? or what?
Unread 09-02-2009, 18:59
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: AI Programming
Closest to or farthest from what?
See this thread for more info:
http://forums.usfirst.org/showthread.php?t=11671
Unread 09-02-2009, 20:26
Re: AI Programming
hmm, so I see the R1, R2, R3 etc. My last question is this, do each of those 'Positions' correspond to any particular starting point, or is it all figured out on each alliance and has nothing to do with your robots' starting position
Unread 09-02-2009, 20:27
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Re: AI Programming
The starting position of your robot will be negotiated with your alliance partners prior to the match and is not related to which driver's station position your team is assigned to.
Unread 09-02-2009, 21:20
Re: AI Programming
ok, thank you very much for everyone's help
Programming in Python and Explaination of Programming roboxking Programming 22 07-01-2008 16:08
programming motors with programming kit BorisTheBlade FIRST Tech Challenge 4 01-11-2005 19:03
programming great_one411 General Forum 1 14-02-2003 11:28
programming archiver 2000 2 23-06-2002 22:59
Programming archiver 2000 1 23-06-2002 22:34
