Go to Post Let's Get Ready to (Graciously) Rumble! - Mr MOE [more]
Unread 07-02-2009, 18:11
dan_h dan_h is offline
EE Grad Student
AKA: Dan Huizenga
#0518
dan_h is an unknown quantity at this point
Can't "undeploy" default code
Help! When I try to "undeploy" the default code from the FIRST menu in WorkBench, I get an "Unable to delete the UserProgram from the robot." error. However, when I try to download my own code and run it, I see the following error in the console (I have the target IO redirected to a target console):
"Error: Other robot code is still running... Unload it and then try again" (see below)
Does anybody know what's going on here?! I do have my team number set for the FIRST utils in WorkBench ... I'm stuck. Help!
Team 518 Home Page
Unread 07-02-2009, 18:55
byteit101's Avatar
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
Re: Can't "undeploy" default code
are you FIRST>Download(F>D) or Run Kernel Task (RKT)?
you have to either F>D, Reboot, test, F>Undeploy, modify code, Build, and repeat
OR
RKT, test, reboot, modify code, and repeat
Watchdog.Kill();
Unread 09-02-2009, 19:33
csshakka csshakka is offline
FRC #0818
csshakka is an unknown quantity at this point
Send a message via AIM to csshakka Send a message via MSN to csshakka
Not 100% sure, but i think you can go under the remote connection that you've created and look through the processes running on your robot. You can delete whatever your program was called.
Unread 09-02-2009, 19:49
EE Grad Student
AKA: Dan Huizenga
#0518
rkt, as described here: http://thinktank.wpi.edu/article/137
Team 518 Home Page
Unread 09-02-2009, 20:02
EE Grad Student
AKA: Dan Huizenga
#0518
It finally undeployed (I don't know why, exact same procedure I tried on Saturday) >:-(, but it's running now
Team 518 Home Page
Unread 09-02-2009, 23:46
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
If all else fails you can FTP into the cRio and delete the file.
"Why Johnny can't code" Astronouth7303 Programming 19 22-10-2006 03:08
Modified default code gives "code violation" scottmso Programming 8 10-02-2006 23:17
Code error on RC after downloading "bells and whistles" version of Kevins camera code DanDon Programming 6 10-01-2006 18:07
"Thunderbirds" Vs. "Team America" Which one will rule the box office? Elgin Clock Chit-Chat 3 07-09-2004 19:53
Can't Compile the Default Code pressurex1 Programming 4 25-01-2004 20:26
