Go to Post Pneumatic components always give me gas... - Alan Anderson [more]
Unread 07-02-2009, 16:51
MBernstein MBernstein is offline
FRC #2888
MBernstein is an unknown quantity at this point
Optical encoder not returning values
Our optical encoder is only returning 0.
We would like an example source code for getting the number of rotations.
Also the LEDs inside do not light up...should they be?
We have it connected to the Digital I/O of the digital side car.
Unread 07-02-2009, 18:24
Steve_Alaniz Steve_Alaniz is offline
FRC #2848 (All Sparks)
Steve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond reputeSteve_Alaniz has a reputation beyond repute
Re: Optical encoder not returning values
Just for a test, I connected a USdigital quad encoder to the crio using the included example encoder code and it worked great. Does that help? OK some LEDs are infrared so you wouldn't see anything but if you have connected 5V before and seen the led light... then of course the answer is yes. The USdigital encoder light is encased so I don't see light from mine.
Steve
Unread 09-02-2009, 12:09
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
There is an example here:
C:\Program Files\National Instruments\LabVIEW 8.5\examples\FRC\Digital\Encoder Example
Make sure you have it wired correctly.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 09-02-2009, 12:10
MrForbes's Avatar
AKA: Jim
FRC #1726 (N.E.R.D.S.)
If you want to see if an IR LED is lighting up, look at it with a digital camera
Unread 09-02-2009, 12:35
TheOtherGuy's Avatar
TheOtherGuy TheOtherGuy is offline
Unregistered User
AKA: Kevin Forbes
FRC #4183 (Bit Buckets)
TheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond reputeTheOtherGuy has a reputation beyond repute
Have you wired it correctly? There should be a +5, A, G, and B on the encoder.
PWM 1 - black to G, red to +5, white to A
PWM 2 - black to G, red to +5, white to B
The second PWM cable doesn't really need the ground and power connected. Since you didn't provide enough information, are you sure you connected both the A and B channels and selected the right ones in LabView? (are you using LabView or C++?)
Unread 09-02-2009, 12:49
Jetweb Jetweb is offline
is good at making robots find walls
AKA: Jonathan
FRC #0179 (Children of the Swamp!!!)
Jetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to allJetweb is a name known to all
If you dont see a red light stop altering your code, the sensor is wired incorrectly or it is broken, we have 5 on our robot so i know there is supposed to be a visible red light inside (with the top off of course)
Unread 09-02-2009, 20:23
dpc131's Avatar
dpc131 dpc131 is offline
AKA: Dan
FRC #0836 (Robobees)
dpc131 is a jewel in the roughdpc131 is a jewel in the roughdpc131 is a jewel in the rough
Quick question for anyone. I just got back to the team and saw that they incorrectly hooked the encoders to the Analog I/O and not digital. I believe that the encoder were over-voltaged. They seem to have failed high, lights illuminates, but no pulse on the O-scope. Anyone have any luck with Overvoltage and still operational?
Dan Cell
Systems Eng. Mentor
Team 836 - The Robobee's
Unread 09-02-2009, 20:26
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
Both the Analog breakout and Digital Sidecar provide 5V on their power pins so connecting the encoder to the wrong board should not cause a problem.
Unread 09-02-2009, 20:59
FRC #2888
Thumbs up Re: Optical encoder not returning values
I believe we do have it wired correctly, as it matches what you state above (we don't use the ground and power on the second PWM cable). Originally we connected it to the analog i/o but then realized it needed to connect to the digital i/o.
We are using C++ and have test code like the following, just to verify the encoder is working correctly:
Encoder encoder(1, 2, true);
while (1) {
count = encoder.Get();
cout << count;
We then rotate the middle of the encoder, but the count stays at 0. How should we be using the Encoder class to read values from the encoder?
Unread 09-02-2009, 21:50
While I'm not sure it's completely necessary, when I last used them in C++, I called encoder.Start() before I started trying to read anything.
Unread 09-02-2009, 22:00
dpc131's Avatar
AKA: Dan
Wow, long day at work and robotics. Looks like I didn't practice what I preach and read the manual. I saw the 10V stamp on the module and didn't think about the bumper having it's own power supply. Thanks for the catch, and that's one de-merit for me.....now I just need to find out what is actually wrong with it....
Dan Cell
Systems Eng. Mentor
Unread 09-02-2009, 22:10
AKA: Jonathan
Just reminders you probably already know...
Make sure the encoded wheel is 1 un-scratched, and 2 installed to the proper height with the included placement wheel also it will not work without the cover on tightly.
optical encoder feedback windriver darkorbit C/C++ 2 17-01-2009 13:34
Optical Encoder Centering Tool Gary Bonner Kit & Additional Hardware 1 05-01-2009 18:19
A nice and cheap optical encoder! (not a question) windell747 Electrical 9 04-05-2008 14:13
AHH! Not returning to FIRST! Can't See Me General Forum 19 07-10-2005 14:07
Rotary Encoder (optical etc.) Gary C Technical Discussion 4 16-01-2005 18:23
