Go to Post Super Bowl, P-Diddy, Diet Pepsi. Super Bowl of Smarts, Dave Lavery, Diet Coke. - Gary Dillard [more]
Unread 09-02-2009, 19:09
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
Can any one help us with programing the encoder to control the motor by ticks?
i wonder if any one knows how to set up the motor to move to ticks?
making a motor into a absolute value like a servo..
any help here?
Unread 09-02-2009, 20:15
Re: Can any one help us with programing the encoder to control the motor by ticks?
any oneee???
Unread 09-02-2009, 20:26
Motors alone cannot do this. If you add a pot or an encoder, then you have a shot. Another way to go about this is with limit switches.
It is reasonable to think of a servo as a motor, a pot, and a loop that quickly adjusts the motor speed based on whether the pot is too low, too high, or just right. If you get a pot or encoder hooked up, try making a periodic task to read the pot and set the motor.
Greg McKaskle
Unread 09-02-2009, 20:28
i got the encoders from the kit already set up and mounted on a banebot motor we are using to control our lazy susan
Unread 09-02-2009, 20:54
So, now you are missing code to read the encoder and compare the value of the encoder to the value that you want it to be. Then set the motor either forward, backward, or stopped depending on the error. Once you get it working to some degree, you can look at adding PID to make it be better controlled.
Greg McKaskle
can we control the amount of air to control the speed of the cylinder? Team2339 Pneumatics 22 11-02-2009 15:33
[FTC]: [FTC]: Can any one explain to me just how powerful the servos are? sullivan_owns FIRST Tech Challenge 19 02-12-2008 16:06
programing the vex optical shaft encoder youngWilliam14 Programming 10 11-11-2007 16:16
can anyone please tell mw where or with what can i lear programing in C techsage Programming 7 23-08-2005 00:25
Has any one stuck a drill motor in the FP trans? Lotownvw Motors 15 21-04-2003 23:57
