Go to Post This is a community that builds people as well as knowledge. - Karibou [more]
Unread 09-02-2009, 20:28
Must Be Drama Must Be Drama is offline
Must Be Drama is an unknown quantity at this point
Re: Can any one help us with programing the encoder to control the motor by ticks?
i got the encoders from the kit already set up and mounted on a banebot motor we are using to control our lazy susan
Unread 09-02-2009, 20:54
So, now you are missing code to read the encoder and compare the value of the encoder to the value that you want it to be. Then set the motor either forward, backward, or stopped depending on the error. Once you get it working to some degree, you can look at adding PID to make it be better controlled.
Greg McKaskle
can we control the amount of air to control the speed of the cylinder? Team2339 Pneumatics 22 11-02-2009 15:33
[FTC]: [FTC]: Can any one explain to me just how powerful the servos are? sullivan_owns FIRST Tech Challenge 19 02-12-2008 16:06
programing the vex optical shaft encoder youngWilliam14 Programming 10 11-11-2007 16:16
can anyone please tell mw where or with what can i lear programing in C techsage Programming 7 23-08-2005 00:25
Has any one stuck a drill motor in the FP trans? Lotownvw Motors 15 21-04-2003 23:57
