Re: Driver Station Digital Input
Jeremy,
Lucky for you that this input is somewhat fault tolerant. Use an ohmmeter to determine the pin arrangement on your switch. Connect one pole to +5, the other pole to ground and the common to the signal pin. Mike |
Use a 10 k resistor to tie the signal to +5 volts, rather than directly to signal. In theory it shouldn't matter but the resistor is the common industry standard way, because it ensures that errors won't cause damage. You can even connect the +5 to signal through the 10 k resistor and just short the signal to ground with the switch...with impunity!
Don |
| drivers station digital input trouble | finman | Electrical | 9 | 16-02-2009 08:06 |
| Driver Station Input | SwampDogs | NI LabVIEW | 3 | 27-01-2009 11:33 |
| driver station digital outputs | DustinB_3 | FRC Control System | 0 | 24-01-2009 11:29 |
| Flashing Driver Station Digital Input | MacGyver1718 | FRC Control System | 3 | 15-01-2009 19:22 |
| Interrupt on driver station digital input | Nameless | Programming | 9 | 04-12-2008 16:55 |
