Go to Post I looked at it and originally thought it was a crazy idea... then I looked at it again and it still sounds like a crazy idea. But crazy ideas tend to produce some excellent results. - Yipyapper [more]
Unread 09-02-2009, 21:35
UberChar UberChar is offline
AKA: Jerry Agbayani
FRC #1558 (ACCIdent)
UberChar is an unknown quantity at this point
Creating the trailer hitch
ok i read the manual but i didnt see any thing on how to make the trailer hitch can someone provide the diagram on how to make it or step by step instructions?
Unread 09-02-2009, 21:47
dani190 dani190 is offline
AKA: Dani
FRC #2185 (RoboRams)
dani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to beholddani190 is a splendid one to behold
Send a message via MSN to dani190
Re: Creating the trailer hitch
try looking here
http://usfirst.org/uploadedFiles/GE-09040_B.pdf
and
here http://usfirst.org/uploadedFiles/200...20Drawings.zip
under GE-09036_revB
Unread 10-02-2009, 20:45
AKA: Jerry Agbayani
I've seen those diagrams before but we just don't know how to make the part that you put the bar on for the trailer the diagram on GE 9036
Unread 10-02-2009, 20:50
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
I'm thinking you are talking about the trailer tongue. The part that is on the trailer. If it is just for your testing we made ours out of a chunk of 3/4 conduit.
Bruce
Unread 10-02-2009, 23:28
haxor5354 haxor5354 is offline
AKA: Jason
FRC #1558 (ACCI-DENT)
Team Role: Electrical
haxor5354 is an unknown quantity at this point
so the hitch is just the spacer "smacking bar" and the u shape piece of metal with holes on it?
Unread 10-02-2009, 23:36
GUI GUI is offline
AKA: Gary
FRC #4183 (Bit Buckets)
GUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to beholdGUI is a splendid one to behold
Send a message via Yahoo to GUI
Yes, and the "u shaped piece of metal with holes on it" is made by cutting out a 7" long section of the kit frame c channel with one of the pre-drilled 1/4" holes in the center. If you cut 7" off the stock end of one of the channels the hole will be in the proper location (unless your kit frame is different than ours, you never know so double check).
Unread 11-02-2009, 08:15
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
Even if it isn't in the proper spot (like ours) it is easy enough to measure and drill out the proper holes. Though it is slightly annoying.
Trailer Hitch punjabiblood Technical Discussion 12 26-01-2009 20:19
Trailer Hitch ewyllie59 Technical Discussion 8 24-01-2009 15:00
Trailer Hitch Location geekofband007 Rules/Strategy 6 06-01-2009 19:46
Trailer Hitch ewyllie59 General Forum 7 06-01-2009 08:33
