Go to Post If you can't make them fit on the robot, then those features don't really add much value. - Cory [more]
Unread 09-02-2009, 22:14
lscime lscime is offline
AKA: Luke Scime
FRC #2614 (Mountaineer Area RoboticS (MARS))
lscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to beholdlscime is a splendid one to behold
Vid: Martian Adaptive Drive (MAD) #2614
This year our robot (Marvin II) has the ability to transition between crab drive (wheels at 45 degree angles) and all 4 wheels in a straight line (in-line) using two small pneumatics. We use in-line when we want max acceleration and Arcade-type steering and crab when we want to translate, move diagonally, brake, or do a crazy pivot spin (makes us very hard to score on). Each wheel is mounted on a shock so that we maintain contact with the ground even when transitioning between the regolith and the carpet. Each wheel is mounted on on an Andy Mark Gearbox and is optically encoded for PID traction/slip control and on the fly acceleration limiting. We can suck up balls or be loaded by our human players. While we have to get in close to dump our hopper holds somewhere in the range of 25 balls.
More videos comming soon. (Thankyou 1629 for use of your field)
All comments welcome, and enjoy!
http://www.youtube.com/watch?v=TfDhW9vHomU
Unread 09-02-2009, 22:35
Guopeter Guopeter is offline
AKA: Pie
FRC #0296 (Northern Knights)
Guopeter is just really niceGuopeter is just really niceGuopeter is just really niceGuopeter is just really nice
Re: Vid: Martian Adaptive Drive (MAD) #2614
Hey 2614,
Looks like a nice bot you guys got there!
Will you be at WAT this year? If so, hope to see you there!
-Peter
2609 BeaverWorx
Unread 09-02-2009, 23:03
BradMello's Avatar
BradMello BradMello is offline
Broken Arrow
FRC #0078 (Rhode Rage & AIR Strike)
Team Role: Driver
BradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant futureBradMello has a brilliant future
Send a message via AIM to BradMello
Interesting idea having your wheels ride at a 45 degree angle, good luck!
Team 2614 Teaser #1 lscime Technical Discussion 2 23-01-2009 12:22
Vid: Our drive team can-can dance.... OScubed Chit-Chat 1 13-04-2008 12:04
pic: Martian Death Grip Gene Williams Extra Discussion 3 09-01-2007 12:57
Robot Adaptive Suspension Andrew Blair Technical Discussion 13 09-09-2005 12:02
Adaptive Parts Tarzan Inventor 4 29-01-2003 12:58
