Go to Post Note to self: Before turning 30, remember to remove the birthdate year from Delphi. - Jessica Boucher [more]
Unread 09-02-2009, 23:27
Chipawa's Avatar
Chipawa Chipawa is offline
AKA: Mr. Tucker, AKA Chip
FRC #1111 (Powerhawks)
Chipawa is an unknown quantity at this point
Allocation of PWM and GPIO Channels
We have a lot of motors and limit switches on this year's robot. Is there any reason we cannot use (for example) PWM channels 1-8 and GPIO channels 1-8 from the same digital sidecar?
And if so, how do you address those channels in code?
We're programming in C++. I'm not a programmer, but I understand that you have to specify a slot and a channel number for each signal. I'm just not sure how you differentiate between a PWM channel and a GPIO channel. Any help would be appreciated.
2010 DC Engineering Innovation Award
2010 DC Spirit Award
2008 Chesapeake Finalist
2008 Chesapeake Rockwell Automation Innovation in Controls award
Unread 09-02-2009, 23:35
wt200999's Avatar
wt200999 wt200999 is offline
Texas Instruments
AKA: Will Toth
FRC #3005 (Robochargers)
wt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud ofwt200999 has much to be proud of
Send a message via MSN to wt200999
Re: Allocation of PWM and GPIO Channels
You can use all of the inputs without having to worry about conflicts. When you specify the slot and channel number (or if you are using the default slots just the channel number) the object you specify it for will tell whether it is a GPIO or a PWM.
Programming in LabVIEW? Try VI Snippets!
FIRST LEGO League 2004 - 2005
FRC Team 870 Student 2006 - 2009
FRC Team 3005 Mentor 2013 -
Unread 10-02-2009, 14:13
Chipawa's Avatar
Thanks for the reply. Glad there are no conflicts.
I'm still not sure how you differentiate between a GPIO and a PWM. Is there a separate "GPIO #" and "PWM #"?
Unread 10-02-2009, 15:21
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
The digital side card has 10 PWM ports for driving victors / jaguars. If you need more PWM ports you can add a second digital side card. If you have some low current motors (CIM or Fisher Price must be connected to a speed control) that run in an on/off fashion you can drive them with a spike according to <R54>.
edit: Also all the Spikes and Speed Controls must be connected to the designated port, you cannot drive them with GPIO.
Unread 10-02-2009, 15:31
If you open a Jaguar or Victor or Servo object, it will know that you intend to connect it to a PWM output. If you open a Encoder or switch or etc object, it will know that you intend to connect it to GPIO. If you open a relay object, it will know that you intend to connect it to a relay output.
Unread 10-02-2009, 15:34
You differentiate between them by choosing Digital I/O classes vs. PWM (Victor, Jaguar, Servo) classes. There are also separate Relay numbers, Analog numbers, and Solenoid numbers.
Unread 10-02-2009, 17:25
Chipawa's Avatar
Thanks for the help all. We are trying to cut weight where possible, so we're trying to stick to just one digital sidecar. Looks like we'll be able make it work.
Unread 11-02-2009, 00:36
RoboMaster's Avatar
RoboMaster RoboMaster is offline
Alum, former programmer&co-captain
FRC #2472 (The Centurions)
RoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant futureRoboMaster has a brilliant future
Well, you are programming in C, so this might be of little help, but this is what I have noticed in LabVIEW:
You can open up the Set and Get VIs (VIs, or SubVIs, are like functions in C) for the PWM input/output plugs and see what they actually do to make controlling the PWM signals. They actually use the Counter VIs to make/read the signal that is going through the pins to sense the ups and downs, ultimately a PWM signal. Then they handle sending/recieving signals through the port similar to a regular digital input-output port.
I would suggest looking into this on the C side and see if you can look into the functions that allow you to control PWM signals. I'll bet they too use counting processes to read/write a PWM signal from scratch. Then you can make your own code that does the same or copy and paste some of those formulas' code, but instead modify it so that it is controlling a digital input/output port/slot/pins.
I hope this makes sense. Cheers!
My engineering blog: noeticbrainwaves.blogspot.com
I'm not slacking, my code's compiling
...and I'm using LabVIEW
Dashboard Analog Meters and GPIO? Geek_Girl Programming 1 17-12-2008 09:50
Dynamic Memory Allocation Woes slavik262 Programming 7 12-02-2008 16:15
Random Allocation of Trackballs fabalafae Rules/Strategy 7 07-01-2008 09:31
Please help: Memory allocation problem dealing with sections RbtGal1351 Programming 10 14-03-2006 14:58
Split topic - How many channels can the current (2004) Oi's and Rc's Handle? Elgin Clock Control System 6 02-01-2005 14:02
