Go to Post FIRST isn't chaotic; the rest of the world just moves in slow motion! - StephLee [more]
Unread 09-02-2009, 23:50
NumBeast NumBeast is offline
Head Code Monkey
FRC #1011 (CRUSH)
NumBeast is an unknown quantity at this point
Re: Doesn't execute teleop execute case
This might or might not be your problem, but in begin.vi your newly opened encoders aren't wired into your robot data structure. They're kinda just hanging there...
All signatures are false.
Unread 10-02-2009, 08:08
As mentioned, your encoders aren't hooked up. Also, you have a start communications in the Vision VI.
I don't see anything that would make Begin run more than once. Put a breakpoint on something like an open node in it. Right click and set breakpoint. If you hit the breakpoint more than once, the stack crawl ring at the top of the window will show who is calling.
I think you'll find that there is only one call. Sorry I couldn't be more help.
Greg McKaskle
Can't get program to execute Thxe C/C++ 3 09-02-2009 08:33
Telling Labview which loop to execute first professorX NI LabVIEW 5 02-02-2009 15:15
execute.h magical hands Programming 2 10-03-2007 21:02
EasyC: Execute code before autonomous Greg Marra Programming 7 07-01-2007 21:30
How I can execute Javascript into Perl? TomS Programming 3 22-08-2006 16:35
