Go to Post Good thing you skipped this year. You don't need exhaustion to sleep through Recycle Rush. - Gregor [more]
Unread 10-02-2009, 07:39
Betty_Krocker Betty_Krocker is offline
Fabricator/Hacker/Comic Relief
AKA: Michael
FRC #2028 (Phantom Robotics)
Betty_Krocker is an unknown quantity at this point
Send a message via AIM to Betty_Krocker Send a message via Yahoo to Betty_Krocker
Break Out Board???
I haven't been able to find a set answer, so I am asking the audience...
If we are using Pneumatics, do we HAVE to use the Break Out Board, or can we go with a spike which we have been doing since the dawn of FIRST? Our programmers have the break out board and would love if we can use spikes because they have the program for it already...
"Measure once, cut twice... wait... what?"
"Two things needed to build a robot.. WD40 for the things that don't move but should, and Duct tape for the things that move but shouldn't"
Unread 10-02-2009, 07:55
Russ Beavis Russ Beavis is offline
Russ Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond reputeRuss Beavis has a reputation beyond repute
Re: Break Out Board???
You'll need to use a Spike for driving the compressor but you're free to use either Spikes or the Solenoid Breakout for driving pneumatics valves.
Russ
Unread 10-02-2009, 08:48
AKA: Michael
Alright thanx a lot because that makes our programmers job easier...
Unread 10-02-2009, 09:09
Really? If the code is from last year, it is going to have to be modified. If it has to be modified, it is equally easy to go either way.
Unread 10-02-2009, 09:13
AKA: Michael
no they said something about not liking labview or the break out board and electrical dept doesn't like wiring the break out board either, and they already have the spike code up and working...
Unread 10-02-2009, 09:49
I don't really care either way, but it seems like you have some feedback that the developers should have access to - continual improvement and all.
If you have any specific "I don't like X because of Y" or "A should be more Bish" comments please share.
Unread 10-02-2009, 10:26
Mike AA's Avatar
Mike AA Mike AA is offline
Programmer and Mentor
AKA: Mike Aalderink
FRC #3458 (Code Blue)
Mike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to beholdMike AA is a splendid one to behold
Send a message via MSN to Mike AA
One thing to think about is with the breakout board you can connect multiple solenoids. You need a spike for each solenoid you want to control, plus all the wire to power the spike. If you have more than 2 solenoids the breakout board will most likely be less weight and much much neater.
I didn't really like Labview at first either but all of a sudden the other night it just clicked and I realized how easy it really is and you dont have to worry about missing a single letter or puncuation.
-Mike AA
Figure out what's wrong with the IR board sparrowkc Electrical 5 17-02-2008 12:29
spring break thatphotochick Chit-Chat 6 29-03-2006 17:41
Need a little help with how to break out of the box amateurrobotguy Programming 6 16-01-2006 12:56
Perf Board = BS2-IC Carrier Board? indieFan Electrical 2 16-09-2004 08:28
Before I break anything... Dmitri Motors 7 10-02-2004 20:36
